Surely each manufacturer should provide specifications and measurements for their own products?
Keith
This response doesn't have anything to do with what you were demanding and claiming previously!
david
Keith
I hope it's not to late to join the party. I almost feel like a gate crasher entering the party after the fun and revelry is over, most of the guests have gone home, there is little food though there is some booze. David suggested on my systems page that I join so here I am. I have read with interest the entire thread, often amused, sometimes puzzled but always a fun read. In the 390 odd posts there are less than half a dozen addressing the sonic attributes of the different drive systems.Getting back to the 3 original Reference tables, each tt has some very specific sound characteristics associated with its drive type and are great representatives of that technology. Frankly, I didn't expect the limited experience of people with these tts in this forum so things came to halt and conversation went a different direction. I tried to explain some of the basic qualities of each technology not to pick a best but offer different flavors for enjoyment and variety. This is one of the greatest beauties of analog vinyl that while all 3 tables sound totally different they're also all correct and musical at the same time, digital can't do that!
david
Let me pitch in with my 2 bits. I have 2 TTs. In the left hand corner, an idler drive Garrard 401 with a Lyra Atlas mounted on a 12"Ortofon 309D arm and in the right hand corner a TW 3 AC modded all the way to BN status minus the BN platter+feet. The TW has a Durand Talea2 arm and a Lyra Etna. Both TTs are on independent wall mounted shelfs and the tone arm wires have been burnt in using a special wire gizmo that was specially fabricated . The carts are aligned with customised Mint LP Best protractors. The 401 is plugged into the MC inputs of a Nagra VPS phono while the TW is plugged into a Ortofon 80 SE SUT which feeds the MM inputs of the same phono stage.
To provide some context I have not listened to my system for over a week as I am recovering from eye surgery. I fired it up last night with the express purpose of trying to focus on the differences/similarities of both TTs. I played the same tracks/Lps sequentially on both tables starting with "Another brick in the wall" and " Comfortably Numb", from The Wall, the complete 1st side of Stowoski's Rhapsodies, Ernest Ansermet" The Royal Ballet" and finally the 45rpm Lyn Stanley " Potions".
For me this was not a controlled test but something I have been doing for the past 2 years. Namely start an LP on one TT and listen to side 2 on the other TT.
Now for the disappointing bit. The similarities to my ears outweigh the differences. Off course the sound is not identical but each TT will overwhelm you with the music unless you want to be completely anal and focus on a piano note or a drum beat to the exclusion of what the music is doing. I am willing to bet that were I to do a blind test with someone not familiar with my system, using the same track/LP he/she will find it difficult to distinguish between the TTs. I know blind testing has its limitations etc but I mention it to illustrate the point that properly set up TTs playing through a revealing system will sound more similar than different.
I happily acknowledge David's analog expertise but I am unable to concur with the view that different drive types have an indelible sonic signature that is easy to catch. It may be so but my listening experience suggests otherwise.
My audio buddies will be visiting soon and I will be happy to share their impressions. One of them is a designer of SET amps and single driver speakers and I am sure his ears are more accomplished than mine( sounds like Dr Spock ).
Sorry for a long rant.
Pradeep
Pradeep
Hi Pradeep
Great to hear you playing with multiple tables
IMO the TW Raven and the Garrard may have similar traits in how they handle mid bass. The Raven AC3 IMO has a upper bass bump which makes it sound nice with a lot or recordings. I assume the Atlas and Etna are more alike than different?.
I feel if you had a DD table the differences may be more obvious.
My DD tables are a lot more neutral through the bass and have less mid bass. They have a different feel in the upper frequencies, more direct but less " air " ?. The amount of mid bass in the system has a profound difference in how much musical detail one years. Changing rooms recently reinforces that notion of how much my previous room was masking.
That said, favourite albums don't sound fundamentally different on either table once you play a couple of track's. Your ears do a pretty good job in equalising.
Cheers
XV-1, That is interesting about the mid bass. What do you think accounts for that with Pradeep's belt and idler tables? I agree that excessive mid bass robs the sound of detail.
You're very welcome Frantz. I don't mind those who appreciate their own choices in equipment but I try not to 'bash' those choices about which I have my doubts...
I have both a belt-drive Raven AC-2 and several DD Victors and can happily listen to all. Implementation is more important I suspect, than actual 'religion'?
Components should sound more alike if they are all equally accurate. The problem with turntables is that it is easier to damage the sound than benefit the same. There are thousands of ways to screw up turntable sound and a far narrower path to optimising them.
my 3 turntables; the high mass platter, string drive, air bearing/cushion CS Port, direct drive Wave Kinetics NVS, and idler Saskia have much more in common with their performance than differences. each brings degrees of positive attributes relative to their drive design, but the level of execution of each is such that drive type artifacts are not evident.Components should sound more alike if they are all equally accurate. The problem with turntables is that it is easier to damage the sound than benefit the same. There are thousands of ways to screw up turntable sound and a far narrower path to optimising them.
