Has anyone moved on from idlers, Garrards??
Melco and Dava
you running belt?
Yes, tried different threads and there is a certain amount of slippage resulting in less than ideal speed stability.
None of it with belt. I got it from DDK and he thinks belt is very close to thread sound wise
Reactions: mtemur
what is distance from side of platter to center of pulley pls?
that Melco is crazy beautiful. i love that massive weight. it is just so OTT.
how do you rate the Derenville motor? i am looking to get a new motor for my Platine. i have built an AC motor and it sounds great. i presume there is more to get from a motor like the Dereneville or Galibier though?
I’m also interested in an aftermarket motor for future project - looking at this one if anyone knows it, would be great to hear your thoughts
That is in line with my experience. I only tried a few threads but a high quality belt is better sounding.
I know Basis made some superprecision belts, but where can one get something like that, but longer?
I use Transrotor Lang belt. I’m sure there are better options but it ticked all the boxes for me because it doesn’t over stretch or deteriorate over the years, it has a small diameter, doesn’t change elasticity between summer and winter etc.
I found this
@Maril555 did you use mylar or tape when you had the Galibier or was that thread too at that time? i am thinking about moving from thread to tape and so am interested if anyone has any experience.
Ive tried different distances, starting with 1 m that Melco recommends to about 1 ft, same results.
I should try different threads material, as i got a feeling Kevlar thread is too slippery
Dereneville is great, has 4 speeds and very user friendly, tons of different functions
