naaah. i just happen to wander through.....Since you were off for a few days, I though you were busy setting up a new system
i think that the CS Port LFT2 with linear tracker, the Wave Kinetics NVS, the appropriate J. Sikora, the Brinkman Balance, or a Saskia if you can find one would all be 'not limiting' and in the properly accessorized and sorted system context would take you to a high level. these are just one's off the top of my 'currently distracted' head.Mike, what turntable would you recommend for under $50K? Which table are you now most listening too, or does it still matter on mood and genre and what you feel like at the moment? You have some good choices.
I also learned to appreciate vacuum hold down. Who knew?
Anyone remember which TT brand and model was the first to use vacuum hold down, was it Micro Seiki? I believe Sota was one of the early adopters, so was Versa Dynamics!
Luxman pd 555 vds (vacuum disk stabilizer 1979 patent)Anyone remember which TT brand and model was the first to use vacuum hold down, was it Micro Seiki? I believe Sota was one of the early adopters, so was Versa Dynamics!
![20180206_173500[1].jpg 20180206_173500[1].jpg](https://www.whatsbestforum.com/data/attachments/131/131504-10239ab902d4e39a61afd934625c22d3.jpg)
Even the strongest air pump ever built can only achieve a vacuum of 1 bar. So, the power of the pump is not relevant; even a small pump can easily handle 1 bar (none of them can achieve absolute vacuum and it’s not necessary). When complicated mechanical and electronic devices such as air-levitated platters, vacuum hold-down systems, and precise speed control are involved, I would put my money on Japanese engineering rather than Italian. This is purely from a technical standpoint. I haven’t heard the top Vyger turntables, but I trust your judgment that they sound great.The vacuum hold down of techdas sonically is nothing compared to Vyger’s. Possibly due to size of pump
The Vyger sounds quite superior to Techdas with most carts. Techdas would be more reliable based on reports, though Tang did have some software issues with his AF1p that required fixing, and he was on similar chat with other users, things users do not report or forums. I think Techdas is better serviced for sure. It's probably more consistently engineered as well.Even the strongest air pump ever built can only achieve a vacuum of 1 bar. So, the power of the pump is not relevant; even a small pump can easily handle 1 bar (none of them can achieve absolute vacuum and it’s not necessary). When complicated mechanical and electronic devices such as air-levitated platters, vacuum hold-down systems, and precise speed control are involved, I would put my money on Japanese engineering rather than Italian. This is purely from a technical standpoint. I haven’t heard the top Vyger turntables, but I trust your judgment that they sound great.
I’m sure the top Vyger turntables sound great, but I haven’t had the chance to hear them yet.The Vyger sounds quite superior to Techdas with most carts. Techdas would be more reliable based on reports, though Tang did have some software issues with his AF1p that required fixing, and he was on similar chat with other users, things users do not report or forums. I think Techdas is better serviced for sure. It's probably more consistently engineered as well.
I would never generalize between Japanese engineering or Italian engineering, as I just do not have enough datapoints to generalize, I know only one Italian table. Also by that generalization logic best to buy everything German.
The only time I preferred Techdas was Af3p with Dava. And I heard many, Af3, Af3p, AF1, Af1p, AF2. Including in compares, many carts.
I don’t agree with your view that buying German products is always logical from a technical and engineering standpoint. Japanese products are generally better built and more reliable. Just compare cars, if you like, or electronic products from the 1970s. A German amp or CD player might already be dead or showing issues due to Frako, Roe, or Philips capacitors, while their Japanese counterparts are often still going strong.
Personally, I would prefer a basic design for turntable with fewer complications—a conventional design over complex ones like TechDAS and Vyger. I believe that too many moving parts and intricate circuits are more likely to fail over time. If I had too much money that’s different story then.
I don’t disagree with that principle in general. I really don’t like any other complicated table, I am happy with a Brinkmann balance with Dalby on top. Rest is cartridges and records and signal path
I always consider my La Platine Verdier as a DIYer/enthusiast product. For me it’s like an unfinished turntable requires a lot of experimenting. It’s made from simple easily obtainable parts. That’s a plus but you can never be sure that things don’t go sideways.I don’t disagree with that principle in general. I really don’t like any other complicated table, I am happy with a Brinkmann balance with Dalby on top. Rest is cartridges and records and signal path
What arm and cartridge would you prefer on your Balance? Have you heard Ron’s combination?
That is one of the reasons I bought the Kuzma XL DC i.e. a solid high mass non complicated design with superb engineering quality and reliability (plus it looks amazing and different to a lot of other TTs out there !). And fitted with a great and easy to set-up tonearm from the same Manufacturer, you just can't go wrong with this TT set-up.I’m sure the top Vyger turntables sound great, but I haven’t had the chance to hear them yet.
