The quality of the cable seems to have a far greater impact than the length...as far as the tests I’ve done between 1m, 2m and 10MThanks for your reply. Aside from quality, does the length of the ethernet cable between the two switches matter?
Thanks again.The quality of the cable seems to have a far greater impact than the length...as far as the tests I’ve done between 1m, 2m and 10M
Totally agreed!Thanks again.
It costs just under 400 bucks at the momentBTW, the PS for the REX end does not have to be 24V. The spec sheet says 10-24V is fine. Just figure that a 12V supply with it ought to be capable of at about 2A.
CKKeung (thanks) put me on to the ER>SOTM, or SOTM/SOTM switch concept and it is a significant upstep in dimensionality and that "magic" we elusively try and find.
One very interesting thing for ER users. I was a bit concerned, as many are here, with the heat that the unit puts out. It is considerable and it really heats up the metal shell of my Shunyata SIGMA Ethernet cables. One day I ran it for 5 hours and it was really unpleasant to touch. This is via an Sbooster 12 volt. By the way, the ER does significantly benefit from upgraded LPS in my system.
I became interested in the FARAD Super 3 and ordered a few from Mattijs.( By the way, an absolute pleasure dealing with him. Very knowledgeable and happy to help with any questions; you can tell he has built his expertise through passion and delving deep into audio. Highly recommended).
By the way, the FARAD is really nicely built. Uses the aviation style connector at the PS end. This actually isn't a review of the FARAD (still burning in) but something a bit left field.
I replaced the Sbooster to try the FARAD and got two bonuses. Firstly, the sound of natural instruments is heightened and more dynamic via the FARAD and bearing in mind this is with ten hours on the clock. Those Super caps take a while to burn in as well as the unit. Be sure to use proper isolation and good cabling to bring out what the FARAD can do.
The second bonus - and I cannot explain why, the FARAD runs the ER a LOT cooler. A LOT. The Shunyata cables are now "just" warmish on the B side and ever so slightly warm on the A side. I feel a lot more comfortable with the ER here. Before they were hot.
To illustrate, I used a temperature probe to test - a good 5 hours on each. Same ventilation etc...
B side at the Ethernet plug junction (this is hotter than the A) Sbooster - 38 deg FARAD 29.6 Deg
A side at the Ethernet plug junction Sbooster - 35.8 deg FARAD 27 Deg
Direct measure of the horizontal plate B side Sbooster - 43.6 deg FARAD 38.9 Deg
Direct measure of the horizontal plate A side Sbooster - 38.2 deg FARAD 35.6 Deg
ER top case - SBooster - 40.7 deg FARAD - 37.3 deg
*note that B side is quite a bit hotter than A as mentioned.
Appears somehow the ER is not working as hard. Will be interesting how things go with a 7.5 v supply.
https://faradpowersupplies.com/shop/en/What is a "FARAD Super 3"?
in order from best
2 x sotm best
er + sotm close to above
er + er very good
signle sotm
single ER
It looks there might be much more heat generated with 7.5 v .
mine is very, very hot . You cannot put your hand on it for more than 3 seconds.
with 7,5 v there has to be much more current drown than with 12v .
As far as I remember it was around 4 A at 7,5 v and 1,2 A at 12 v with ER.
Thx Alex - I popped the Sbooster 12 v back in to double check and the ER definitely gets a lot hotter than with the FARAD 12 v. All other things being equal.
