That's called bandwidth, not resolution.
The simple analogy I like to use is x and y axis resolution
On the couple of albums from Yarlung where I have the tape and vinyl, the tape wins.
I've never had a problem with CDs as a format of course. The "crappy" CD sounding good behaviour is one I've mentioned often, and it took me some time to understand what was happening here: simply put, the well behaved CD playback is extracting maximum content from the "poor" CD, and not corrupting it any significantly further - then the ear/brain steps in and filters out what it's after, the musical event, and the "badness" fades away, subjectively.
I've just become more aware of some research studies investigating this ability of the brain - it's called Auditory Scene Analysis, fascinating stuff.
Ok, but as my perspective is mostly dominated by system sinergy and matching, I thought it would valuate the debate. But you are right, most people feel nervous when referring to equipment.
Besides I am currently playing with a pair of Mini IIs upstairs and I am finding them tricky in terms of digital player. They only appreciate the best ...
And if there is glare or typical digital colorations, they have no where to hide.
... "typical" digital colorations?
Jitter, harshness and glare are what I have usually associated with digital when I have heard it in systems which do not cover up these flaws.
Peter....Are the trio of DACS that you referred to in your Goodwins demo Vivaldi, Rossini and the NADAC ? If so, would you rate the Vivaldi ahead on points ? I am curious as to whether you have any 'ears on' experience of the Lampizator DACS ?
Are you certain this "glare" is inherited within these players, or the software?
Again, I can example (and have done repeatedly) "digital-glare" -or- "beautifully extended and delicate highs" ... simply by choosing specific software.
The same goes for LP/Turntables.
Yes, this was an example of one system working correctly, and the others exhibiting flaws. "Digital glare or harshness" is a fault, just like poor speed stability for analogue TT - it's taken a long time for makers of audio gear to get things sorted well enough that just plugging the components together and switching on produces competent sound - buy samples of the latter gear, or work hard on tweaking what you have now ... those are the options ...However, regarding the specific question about "glare": All I can say is that we played the same CDs on three DACS in a row, and one DAC exhibited much more resolution without any sense of glare or digital harshness, and absolutely no listening fatigue. This was the clearest example of hardware differences, because we switched the same software during the same listening session to different DACs. .
Main problem of digital system is digital restoring filters and non-linear distortions. It can "improve" sound too.
But certainly if I had to give two main reasons why CD is always in my view inferior to any analogue, it would be because of digital filtering and digital noise having far more destructive effects than filtering (if used) and noise does in an analogue domain. It is the exact same reason I consider the best digital to be superior to most analogue technology - because the filtering is extremely benign as is a 24 bit noise floor.
I think the article does not tell us anything new. I think it is a typically non-introspective exposition of the view that since CD measures better than vinyl then ipso facto CD sounds better than vinyl, and that if vinyl people choose to delude themselves into thinking otherwise, because they like nostalgia and the feel of LPs, they are simply wrong.
Especially on classical and jazz, in a contest of CD playback against great analog the latter, at least wth very good masterings/pressings, will almost always win -- including against my own current CD playback chain.
Yet honestly, until you have heard a regular 16/44 CD, especially of hard to reproduce instruments on digital (violin, sax) on a dCS Rossini *) through a superb playback chain you don't even remotely know how good the CD medium is. You just don't.
I didn't either. Until I heard it. My jaw dropped. And at this point I am not ready to say that great analog is better than CD playback on the dCS Rossini. I'd have to hear direct comparisons. It was that good. Peter A., who only listens to analog at home and was with me at the dCS Rossini session, agrees that the playback was outstanding and showed all the virtues of great analog playback (except presence and soundstaging, but that was a issue wth the set-up in that room; I have great presence and soundstaging with my own digital).
As for digital filtering, these days CD is usually upsampled to higher sampling rates (that includes the dCS gear and my own DAC), and the filtering from there is the same as for hi-rez digital. My DAC upsamples to 176.4 kHz, the dCS samplng rate is higher. Something like 'brickwall' filtering doesn't apply.
Comparing of different record implementations is hard deal:
1. Almost "invisible" level difference 1…2 dB can «improve» sound perception.
2. Phono correction filter can improve too.
3. Different sound compression that may need/used by technical or other reasons.
etc.
There many variables, that can change sound.
We can’t compare DSD vs. PCM by technical reasons. Comparing digital and analog systems more difficult.
