If “right” is in terms of measurable fidelity, then it is not right.I was referring to your comment that distortion could be perceived as more resolution (which you explain is "not necessarily right").
Saying this necessarily implies that you can make the difference between "real resolution" and "fake resolution". So if you can, why couldn't Ron? Think about it... It is simple logic!
Which begs the question of whether “detail” is enhanced by the harmonics which we are sensitive to?Psychoacoustic studies have shown that most humans have a preferred spectral content and it’s not because of euphony or outlines with sharpies. It has to do with how out ear/brain has evolved to deal with such sounds from the natural world and what we are insensitive to and what we are hypersensitive to.
It seems like you did not understand my point. Never mindIf “right” is in terms of measurable fidelity, then it is not right.
If “right” is in terms of subjective appeal, then it can be right.
I suppose logic can be applied, but I did not consider that approach.
And logic does not usually, or does not always, win in a contest with emotion.
For example, I love the sound of the four box Lamm preamp, but it does not have the resolution of the Boulder 3010. I don't consider this to be a subjective impression. I consider this to be a fact observable by any non-partisan.
Can you be more precise about what psychoacoustic studies you are addressing? As far as I know, most commonly quoted references and pseudo-references address the now old electronics and speakers, not the modern gear having one or more orders of magnitude lower distortion and noise.Psychoacoustic studies have shown that most humans (...)
agree.
flow, nuance and note completion is enhanced by more pure simpler signal paths.(...)
One of the points of a dialogue is that the points can be understood.It seems like you did not understand my point. Never mind
OK…Psychoacoustic studies have shown that most humans have a preferred spectral content and it’s not because of euphony or outlines with sharpies. It has to do with how out ear/brain has evolved to deal with such sounds from the natural world and what we are insensitive to and what we are hypersensitive to.
And give rise to increased dynamic range, contrast, and changes of venue with recordingsWe could say that the added distortion and/or noise of some simpler signal paths enhance some people feeling of flow, nuance and note completion.![]()
It is fair to be skeptical. Of course it is overwrought and exaggerating to declare anything in this subjective hobby to be an objective fact. (Do I always have to draw between the lines?)If that is a 'fact' what is the objective quantum of audio resolution that is measurable apart from any one person's perception and establishes a component's resolution as objective fact? Visual analogies won't help you here.
This is your prediction, not based on your experience. What you mention will need be true on Wilsons not on Altecs if speakers are kept the same, and Boulder on Wilson or YG will have less observable resolution than sets on horns (can think of various combinations having heard both).All I mean is that if we have a full audio system, and in that system we compare a Lamm preamp to the big Boulder preamp, I predict that a statistically significant fraction of audiophiles would find the Boulder to be more resolving. (According to the generally accepted definition of "resolution," not Peter's idiosyncratic version.)
To be fair to me, I wrote "observable." I did not write "measureable."
Apparently the 2nd and 3rd harmonics can enhance our perception of soundstage and detail, as well as 'dynamics' (depending on their phase). Of course they also contribute to 'richness', 'bloom' or 'warmth'.Which begs the question of whether “detail” is enhanced by the harmonics which we are sensitive to?
And whether that is also somewhat influenced by the type of music, like a small ensemble, or a large group?
And yet, the modern gear sounds just as different from one another as gear did in the past, despite the supposed advances you state. What would be then your explanation for hearing these differences? Our imagination? If real and not distortion, then what?Can you be more precise about what psychoacoustic studies you are addressing? As far as I know, most commonly quoted references and pseudo-references address the now old electronics and speakers, not the modern gear having one or more orders of magnitude lower distortion and noise.
IMO most modern high end can't be analysed based on essays or rumors from many decades ago.
And if it does in fact work like that (based on what I have read it doesn’t) ? Wouldn’t you still prefer the one that sounds that way over the one perceptually lacking flow, nuance and note completion…even if it measures orders of magnitude worse?We could say that the added distortion and/or noise of some simpler signal paths enhance some people feeling of flow, nuance and note completion.![]()
Don’t know what you mean by output SPL matching input’s signal.One of the points of a dialogue is that the points can be understood.
Please try again - I may be slow, but I’ll try.
OK…
So is the output SPL matching the input’s signal the best case?
Or which added harmonics are best?
Or is it when there is minimal added harmonics, or maximum SINAD, as being the optimum?
(...) And yet, the modern gear sounds just as different from one another as gear did in the past, despite the supposed advances you state. What would be then your explanation for hearing these differences? Our imagination? If real and not distortion, then what?
