What preamp are you using currently while waiting for your Incito S?
Hegel P30A
The break-in in this case seems more like the breakdown of you mentally until you are forced to accept the new component.
This is like a soap opera, just when you thought you have seen it all there is a twist.
This is why I like matched or proven systems versus this never ending tweaking and suffering by piecing together all these oddball components trying to come up with something that works.
I feel a responsibility for giving you guys a reason to wake up in the morning.
Very interesting! Thank you for correcting me!Unison Research Reference amps: As far as I know very few, if any at all have been imported into the USA, I was only able to listen to a pair in Europe in early 2000s. Bonzo75 & Morricab should know more about these.....View attachment 149752
Why would you route the interconnects through the Gryphon woofer towers if you aren’t using them? That adds two connection interfaces and a second set of interconnects to the 47 foot chain. Seems silly even if it doesn’t impact the sound…which it might.
I guess in the end if the MasterSound amps don’t lose this edginess that is bothering you the question then becomes can you live with it?
It doesn’t matter if your friend thinks you are making too much out of it…he won’t be listening day in and day out to it. If it rose to the level of annoyance to me, then the amps would be gone once I was sure I tried what I could to eliminate the issue.
This is why I like matched or proven systems versus this never ending tweaking and suffering by piecing together all these oddball components trying to come up with something that works. The break-in in this case seems more like the breakdown of you mentally until you are forced to accept the new component.
A plausible theory, but not true. I am agnostic as to whether I deport the Italians or I deport the Frenchies.
Aesthetically, I think both amplifiers are beautiful in their own way (as audio boxes go), so even aesthetics is not a factor at all.
As a dealer of his new Clarisys speakers, I would think there are a few well known amp speaker combinations they seem to satisfy existing customers. Perhaps Ron should investigate this further with the manufacturer and the happy customer base.
No, two different concepts in this context.By agnostic, I presume you mean, indifferent.
Not at all. In fact on that thread I made clear that the opening post is purely theoretical and has nothing whatsoever to do with me personally.Is this why you started the indifference curve thread?
My posted concern about edginess/brightness is impatient hand-wringing until the Italians break in. I don't know anyone on WBF who believes that break-in is nonsense, and that a collection of capacitors, tubes and transformers doesn't change its sound over the first couple of hundred hours. I'm pretty sure even many objectivists acknowledge break-in as a real thing.It seems to me that you are not blown away by either amplifier combination with your new Clarisys speakers.
I don't think a single component can maximize all desired sonic attributes at the same time. Unlike some WBF members, apparently, I have never heard a single component which, for example, is the most resolving and the most natural and the most "musical" and the most dynamic and the most liquid. I think these folks are confused.
Feel free to contact him and get them to post here.I would like to read comments directly from some of the visitors to understand their thoughts about the system
and perhaps a video or two to better understand this issue of brightness.
Ron, respectfully I think this is a mischaracterization. I wrote earlier and I think a few agreed with the post that one confined a component that sounds both natural or musical and is highly resolving. I don’t remember anyone qualifying their comments the way you have by putting “most” in front of every adjective. That is simply not what others are saying. You seem to be confused about what was being stated by others.
The gist of it is that if people are trying two components and they are bothered by different trade-offs or compromises with each one, get rid of both and keep searching for a component that minimizes trade-off and compromises. Within one’s own goals and preferences, this is certainly possible.
I also think most people would pair a Lamm preamplifier with a Lamm amplifier. This combination when matched with the right speaker and rest of the system can sound both natural and highly resolving. I certainly wouldn’t claim the “most“ because it completely depends on the rest of the system context, the room, and every other possible combination. Such a claim would be preposterous.
Maybe just list the amps that will not work with it?The answer to this question is not a mystery. There are a number of well-known amp/speaker combinations that satisfy the manufacturer and existing owners:
Block
Convergent Audio Technology
Jadis
Karan
Soulution
Valve Amplification Company
Vacuum Tube Logic
WestminsterLab
I'm confident ARC and Gryphon would do well also. I would not be surprised if higher end Class D did well as well.
I don't think the Clarisys speakers are picky on amplification.
Incorrect. And I am not referring to the specific brands you chose but the theme of presenting a high res powerful SS amp as more resolution than a SET. I have heard a few systems with Boulder 2160 including comparing the amp, and while it is a high resolution amp, the system resolution has always been quite poor compared to good analog playing through a low watt set into highly efficient speakers with simple crossovers. Because the latter is more closer to straight wire as compared to putting loads of junk in the middle of the signal pathFor example, I love the sound of the four box Lamm preamp, but it does not have the resolution of the Boulder 3010. I don't consider this to be a subjective impression. I consider this to be a fact observable by any non-partisan.
For sure. But how can I list amps that will not work with them if I have not heard the combination in question?Maybe just list the amps that will not work with it?
And not every amp that ill work with them.
Low powered SETs might be on that list…
Most people would likely use some specs.For sure. But how can I list amps that will not work with them if I have not heard the combination in question?
OK - so that was either explicitly knowing that the output was too low, or just a feeling?…
Yes, I agree. As much as I love the Viva Aurora, Lamm ML3 and Absolare PSET (845 x 2) -- let alone sub-20 watt amps -- I never took any action to try them.
OKBut I love these kinds of amplifiers, and the MastersounD in design gets me pretty close (845 x 4 PSET).
agree.Incorrect. And I am not referring to the specific brands you chose but the theme of presenting a high res powerful SS amp as more resolution than a SET. I have heard a few systems with Boulder 2160 including comparing the amp, and while it is a high resolution amp, the system resolution has always been quite poor compared to good analog playing through a low watt set into highly efficient speakers with simple crossovers. Because the latter is more closer to straight wire as compared to putting loads of junk in the middle of the signal path
