Please let me know your experience after you use it.My next active will be a Marchand X126 tube crossover
It has been a while.@thomask - Do you happen to recall what slopes you used on the Lyngdorf and whether you implemented any delays on either of the outputs?
I set up the TDAi2170 yesterday and the results are positive, particularly after running room perfect. I have the speaker outputs going direct to the woofers set at low pass 800hz, which is the factory setting for this speaker, and the analog outputs to a First Watt J2 high pass 800hz. LW 4th order for both. I have not experimented with slopes yet. Nor delays. Everything is clearer, cleaner, more extended, better grip on the 15" woofer. But it has lost a little of the vintage charm, particularly around the midrange. The issue with lack of HF extension, which I thought was probably the horn driver, seems to have been entirely with the passive crossover. Driven actively with the Lyngdorf/First Watt, the highs are very open and extended.
Haven’t had a chance to listen to the videos yet, however due to the nature of a Line Source, and the placement, (way out into your room) I would expect the three dimensional aspect of the “soundstage” to be dramatically different (better) than the Altec’s.View attachment 95030
I bought used Scaena 3.2 on Jan 2000. But due to Covid break, i could not assemble main towers for 30 months.
I appreciate Erik's help in assembly of it last Friday.
During the time, I had been using two Scaena 18 inch subwoofers to augement either Lansche 4.1 or Altec A7.
Now i am doing some comparison between Altec A7 and Scaena 3.2.
Could you tell whether the folllowing musics are from Altec A7 or Scaena 3.2?
Please be entirely candid with us mere observers, and for some , long suffering voyeurs of Thomas’s Altec system videos, do you consider that his Altec A7 are placed in the optimal position within such a cavernous space or do you consider that they would benefit from placement closer to the end wall and corners that they currently face ?The ceiling height drops to a more 'normal' level behind the Altecs, however there is still a substantial open area behind them.
Stage is indeed very different between them.
I wondered if the Altecs might be a touch close together, but space constraints prohibit moving them apart more in the place they currently are. Also, despite horns being less sensitive to this impact than some other topologies, having the full gear stack between them might also affect their stage presentation?
As it was, the stage presentation of the Altecs was actually a bit more 'realistic' although a touch constrained / small. The Scaena throw a huge stage. Fun for sure but maybe a bit larger than life.
Let me guess:@thomask Also has setup the Scaena in a very interesting way. I will leave it to him to disclose![]()
Or even outside in the hot tubLet me guess:
He listens to the Scaneas "backwards", him sitting in the kitchen behind the Altecs![]()
I disclosed all the informaitons to you.We don't even know what drivers and crossovers are in his. Altec went through many versions of their drivers quality declining later add they approached bankruptcy. Some are also made for crown type amplifiers to pump loads of sound into clubs and outdoor rock concerts then to play music at home
Not really the point that I am eluding to … Would you say that the A7’s are placed optimally from a theoretical point of view.We don't even know what drivers and crossovers are in his. Altec went through many versions of their drivers quality declining later add they approached bankruptcy. Some are also made for crown type amplifiers to pump loads of sound into clubs and outdoor rock concerts then to play music at home
It depends on my personal choice.Not really the point that I am eluding to … Would you say that the A7’s are placed optimally from a theoretical point of view.
