Modern speakers vs Vintage speakers
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
So what have we forgotten over time is a good question...
Reactions: PeterA and thomask
thomask
1,623
1,539
275
64
Washington State, US
I pulled the trigger without audition.
It was gamble.
Also, I had to cross the border to BC, Canada from Washington state.
Thus I need to take Covid test.
Also my suv could take only one of them.
Thus I drove 50 miles down to borrow my friend's truck.
It was a lot of hassle.
But it had paid.
Reactions: morricab and PeterA
PeterA
12,684
10,948
3,515
USA
I paid 50K$ for new Lansche 4.1 16 years ago.
It was like buying luxury German car (Lansche is also made in Germany),
But I got Altec A7 four weeks ago at 1000 CDN(750 USD).
Despite the price difference Altec A7 give more effortless sound with nuanced details.;)
Lansche give more refined sound with holographic imaging.
But with Michael Jacson and large scale orchestral music , I prefer Altec to Lansche.
I would think they’re probably better with rock music too. Holographic imaging, pinpoint imaging, and image outlines, are hi-fi stereo attributes which personally I do not hear in live music. I hear energy and life and natural tone and dynamics. The Altec sounds like an incredible value, even a steal for that price. Congratulations.
thomask
1,623
1,539
275
64
Billie Holiday's voice sounds warm and sentimental through Altec A7.
thomask
1,623
1,539
275
64
Peter
You are right.
Altec A7 sounds convincing in playing Pink Floyd;s "Wall"
Reactions: Addicted to hifi
jespera
494
539
200
London
I think that with vinyl the differences would be even more in-your-face. Though it would be difficult to convey on a phone video.
So what makes the A7 so great?
Big horn and woofer?
Alnico magnets?
Construction by people who had natural references and not just digital files and previous generation speakers?
60 years of practice — materials getting better with use?
Do any current speakers match the A7? Outside inbred diciplines such as “3d” and “air”?
Jesper
  • Love
Reactions: thomask
tima
5,860
6,935
1,400
the Upper Midwest
Also, when Thomas says Lansche is better for classical the Altec mids and highs will be less nuanced than the Lansche. They have nice timbre but less nuance. So I always suggest using Radian or TAD there though I also like Altec but if ultimate nuance especially on violin concertos and separation on large scale is the goal.
Can you say which Radian or TAD ?
bonzo75
22,643
13,675
2,710
London
With Radian my reference is the horns Universum which uses the 950 PB (beryllium). Lots of videos here, https://www.whatsbestforum.com/threads/horns-universum-videos.31213/
You will see that the white speaker system and the Red/black sound different on the same music, because of different electronics. There is also a video there of Aviad playing the same cello piece from different performances/recordings, showing a lot of difference. The universum is indeed the most transparent to recordings speaker I have heard and listen to at regular intervals over the last 5 years. The black red one has a 400GBP audio technica AT 33 on a 3k locally made TT with the basic Sikora arm, yet you will hear extremely high nuance on the various violin pieces.
On TAD, it is TAD 4003, and I refer to Leif's system write up here for all the details on why and how http://zero-distortion.org/tad-4003-dual-woofer-flh-leifs-system-norway/
Altec is very good, mind you, nice timbre and pleasant, but less nuanced for violin inflections though imo lesser nuance with the fullness works better for rock as compared to the beryllium counterparts. Maybe if someone added a vdh Strad here it would be sufficient. The problem with many Altec owners is they are lower budget by nature and usually use SPU, shure, etc
I am referring only to the 500 Hz above range, not the woofer. Altec woofers are legendary.
bonzo75
22,643
13,675
2,710
London
Thanks for that write-up. I had seen yr report of Lief's at your ZD. I supect both of these need a fair amount of space.
The upper range doesn't. It depends on the bass solution. Leif uses a lot of space because he can, it is like Mike's or any 4 tower system, you really can't compare it to a normal cone speaker.
The same Radian or TAD can be incorporated in the Altec A7, A5, or A817 design. It is using the Radian or TAD for the midrange, and then using either one or two woofers below for midbass. You require around 4m from the speaker, and as Leif's has a partial rear wave, good to pull it out a bit. The A5, A7, and the uni will not be an all out assault on bass like Leif's.
morricab
9,537
5,068
1,228
Switzerland
Thanks for the follow-up. My room is too small for an all out assault on bass. ~30 sq m. Horn bass is probably ruled out.
Maybe but a TQWT would work nicely...
Reactions: tima
bonzo75
22,643
13,675
2,710
London
I have heard trios with bass horns inn 6m x 5m, and both tune audio Anima and horns universum in average rooms as they are downward firing horn bass. I would have fine with all of them in 20 feet long rooms with at least 4mm. Of course they will be bigger sounding in bigger rooms and can scale effortlessly.
For an analog junkie with classical focus of those I would have gone with universum. The change to change in each LP makes it extremely enjoyable as each is a different concert.
Reactions: christoph and tima
DasguteOhr
2,441
2,621
645
Germany
When you like smooth organic sound test the B&C de 250 16 ohm,
with bigger horn works from 800hz - 18khz. I use it in my open baffles from 2-18khz phantastic driver.
Next level open the back of the Driver let stored energy out you get 19khz.
morricab
9,537
5,068
1,228
Switzerland
DasguteOhr
2,441
2,621
645
Germany
Rensselaer
575
459
275
69
It is not mono but stereo system.
But it still sounds good.
I had talked with my vintage audio guru (Mr Chung) on the phone this morning.
Altec vintage tends to have good value for performance.
The only thing is that they need to be taken care of by someone who know how to clean or repair it.
There are some nice techie who does good work at reasonable cost in Korea.
That is the reason why I audition vintage audio in Korea and plan to ship them to my home in Washington State.
Sorry, what speakers are playing there? They sound great!
Rensselaer
575
459
275
69
JBL Hartfield
Tesla Akr 303
My preference, bearing in mind I am hearing these over my computer speakers, are the Altec A800, so smooth, warm, presence, followed by the Tannoy Autograph, then the JBL and Tesla tied for third (because of a slight edge in the leading transients, woman's voice).
Reactions: thomask
morricab
9,537
5,068
1,228
Switzerland
No...it is a bastard, hawthorne silver iris 15" with B&C de250
Can you try other cds on it? If so, try to get a pair of Beyma CP350TI. You can only get them used but they are simply superb. Almost as linear as the DE250 but lower distortion.
