I would like to hear a pair but I doubt I will ever get a chance in Australia.Once you hear properly set up Western Electric speakers from the 30s you will definitely doubt if there has been any significant advance...
They sound pretty well even in this set up in the middle of room.Aren't the Hartfields corner Speaker?
Like the Klipschorns or Peter's Vitavoxes?
No wonder they did not perform optimally in this set-up away from the corners of the room
And now imagine how much better they sound properly positioned, in the room cornersThey sound pretty well even in this set up in the middle of room.
And then add the 075 tweeter! Or a Fostex...And now imagine how much better they sound properly positioned, in the room corners
@PeterA can certainly tell you about the difference of corner speakers out in the room or correctly (as designed!) positioned in the corners![]()
Good grief. That could not be more wrong.
However, two of my audiophile friends have been exposed to good vintage with my Vitavox speakers and Lamm and they do not seem to really like it. Al may be right: it comes down to preference.
Oooohhhh a dangerous question....Do Ian and Al and/or other listeners find your new system sounds more like or less like what they hear in the concert hall?
Sure Marcel it was just an exampleThere is more than 'just' Western Electric vintage gear let's not forget Klangfilm or Cinemeccanica, some Lomo gear...I get that in the US and region around it Western electric is probably more common, or.... the other stuff I mentioned is likely even MORE rare.
In a few weeks I will be able to listen to a Klangfilm Euronor Junior setup, no it won't ever fit in the new living room ...
I expected so, just making sure nobody gets hung up too much on one single brand.
The interesting thing is that each brand seems to have it's own hallmark sound.
The next best thing is to listen to some youtube footage through your current setup at a fairly high volume, crazy as it may seem it does convey the sonic fingerprint of systems pretty good!I would like to hear a pair but I doubt I will ever get a chance in Australia.
Well Lee, why don't you post some information to back up your comment. Wilsons speakers could have been made in 1960, there is nothing in the speakers that didn't exist then.Good grief. That could not be more wrong.
I'm happy I could enlighten you. Do some simple research, you'll see I'm correct.That’s big news to me.
Probably some of the composite cabinet materials did not exist then. Also, perhaps some of the driver materials (at least in the past they used Titanium and sandwich foam construction woofers from Focal). So, no probably they could not have been made in 1950...not that it matters all that much...Well Lee, why don't you post some information to back up your comment. Wilsons speakers could have been made in 1950, there is nothing in the speakers that didn't exist then.
There were many composite materials including Bakelite that have been around since 1935. It's well known that the Wilson X material is a version of Corian, developed in the 1960's.Probably some of the composite cabinet materials did not exist then. Also, perhaps some of the driver materials (at least in the past they used Titanium and sandwich foam construction woofers from Focal). So, no probably they could not have been made in 1950...not that it matters all that much...
Bakelite was a polymer, not a composite...and as you say Corian was not available until the late 60s ...we were saying 1950. It was probably at least a decade later before it could be shaped into something other than a countertop. The first Wilsons using something like that were probably in the late 80s.There were many composite materials including Bakelite that have been around since 1935. It's well known that the Wilson X material is a version of Corian, developed in the 1960's.
Nothing new here except for the price points.
