I bought a Taiko Tana/Herzan TS-140 a couple of years ago, thinking I would put the Aesthetix Io phono stage amplification unit on top of it. It turns out that the Io on top of the Tana is too tall to fit inside the box compartment -- within the inside dimension -- of my turntable stand. For a variety of reasons I don't want to place the components in a different configuration so the Io could be on the top of the stand.
I've seen you advert on ebay and audiogon for the Taiko Tana/Herzan TS-140. At 3.3 inches tall (?) and the Io Eclipse at 5.5 inches height, that's roughly 9 inches plus I assume you'll want some clearance (what, 6-9 inches ?) above the unit for heat dissipation of all those tubes. However many power supplies you have also have roughly the same requirement. So needed rack space per unit you isolate is roughly 15"-18" height ?
- What is the stand into which the Io and platform do not fit?
- Have you considered using a different stand that can accommodate both phono stage and platform?
- Why don't you want to put the Io on top of your stand?
- Do you have alternatives for isolating your Io?
- What does Jim White suggest for the Io?
- Perhaps it can but the Taiko Tana/Herzan TS-140 does not look suitable for going directly on the floor; would you put it on anything?
- Do you have a reason for looking at CMS and HRS?
WFIW, I have tried Zerovibe, which is basically Herzan, under my turntable and line stage. Ignoring obvious differences between modified Tana and nude Herzan, sonic “effects” in my case were identical but under the preamp they were a bit lower in intensity.Has anyone other than MikeL placed an amplifier on a Herzan? Do we have a second data point on this topic from anywhere in the audio world?
depends on the floor. a solid concrete floor (or wood veneer glued to concrete) is the ideal spot for active isolation. like this.....- Perhaps it can but the Taiko Tana/Herzan TS-140 does not look suitable for going directly on the floor; would you put it on anything?
View attachment 72823View attachment 72822
At the time of experiment (2-3 years ago) I used Zanden 1200 Mk3 but tried only c-j GAT line stage. It was the easiest way to try but don’t think “effects” would be any different under the the phono stage or power amps and as I said, effects under the turntable and line stage were identical but under the turntable they were more pronounced.What do you use for a phono stage?
Have you tried the Zerovibe underneath the phono stage?
Please tell us the sonic effects you hear from turning active isolation on and off -- for both the turntable and the line stage preamplifier.
i can turn the decoupling on and off and the soundstage collapses noticeably. there is also the added precision of detail and nuance. things like piano have a life and textural nuance otherwise unreachable. zero tonal shift or dryness, in fact, the opposite; things have greater ease, timbral rightness, and tonal shading.
some footers expand the soundstage. likely the Tana does that to some degree but my system already is a champ in that category. i don't need more space or scale to recordings.
and the big darts have their own internal suspension for the power supply. no matter they love 'Tana' active.
will all amps react in that same way? might some be voiced for real world platforms? no idea.
2 times i've had friends come over (the amps weigh 160 pounds each) and go through an A/B comparison by listening with the amps on the floor, on stands and on the Tana. both times it was a big thumbs up with the Tana. it was a considerable investment so i was skeptical. no more.
Mike, when you say the soundstage collapses, I presume you mean it shrinks in size. Is this in all three dimensions? Also, beyond the size of the soundstage, can you please describe the quality of the spatial information and of the instruments within the space with the amps sitting on the floor and with the amps on activated Tana platforms?
Tana Active Anti vibration under the Dart monoblocs
We were playing 1/2 inch 15 ips tapes and we decided to observe the active vibration compensation switched on and off. When we turned off the active control, the 3D soundstage collapsed. When we turned it back on, the 3D images coalesced in less than 2 seconds
Mike,depends on the floor. a solid concrete floor (or wood veneer glued to concrete) is the ideal spot for active isolation. like this.....
hifistay Dharma & Twister.Mike,
What is on top of the amps?
Dear Ron,I will be using two Vintage Audio Specialties Nothing Racks. Each one weighs something like 700 pounds. They match the Vintage Audio Specialities American Sound AS-2000 turntable.
In my equipment room configuration, the VTL line stage has to be on the right side which is closest to the adjacent listening room. I also want the Io control unit right below the turntable. From those mandates the necessary positions of all of the components follow. The Io is three boxes and the VTL is two boxes.
I think the current Io Eclipse comes OEM with HRS Nimbus-type footers.
Jim doesn't think the Io needs any other vibration isolation, but he thinks the Herzan could do no harm.
CMS and HRS are two of the most highly regarded and scientifically developed passive isolation solutions.
I believe in the vibration reducing efficacy of the Herzan. I don't think anyone could watch those in vitro fertilization videos and not be impressed by active isolation.
I think many people have concluded that active isolation should not be considered for a turntable unless it is 1) suspension-less, and 2) not very heavy. Even then, many of us have concluded that the self-noise and self-vibration of a turntable renders active isolation ill-advised for any turntable.
However, I think a component festooned with tubes is an excellent candidate for active isolation.
For the VTL amps I would put the platforms directly on the floor, which is engineered wood glued onto concrete slab.
Why would anyone want anything other than Objective 3?
What are Objectives 1 and 2? Is there a 4? 5? Etc.
