I subscribe to Paul McGowan's PS Audio "Ask Paul" vlog. Occasionally there is some good discussion of audio issues even though I find many of his answers rather wrong-headed. Today's entry was "
How to tame bass boom." This is a head-scratcher for Paul. He dismisses bass traps as a solution, even while acknowledging that an active "bass squelcher" device Nelson Pass marketed years ago to feed out-of-phase bass into the room worked, but Paul calls it a bit overkill.
He doesn't mention using electronic equalization even though his subscriber mentioned that as a possibility.
Basically, Paul says that you can try moving the speakers and listening position around and that if that is done in a certain very organized way, this is the best you can do. He recommends relying on competent instructions and a competent set-up man, but then ends with "good luck with that."
He talks about a new subwoofer PS is marketing which will be flat to 10 Hz in room, but will have a switch on it to ameliorate low-bass excess which he calls boom, but distinguishes this from midbass boom. He apparently thinks that while moving speakers and listening position around can fix midbass boom, that method can't handle boom from low-bass excess.
This is a perfect example of how the almost universal adoption of a speaker design paradigm that requires speakers to be placed well out into the room in order to smooth the bass fails us in the lower frequencies. Even "experts" call taming bass boom a very tough problem, or, like Paul, end up recommending the use of other "experts" following detailed instructions as the best solution.
A suggestion: Buy a pair of Larsen speakers and set them up as the manufacturer recommends. Set-up is super easy: as close to the long wall as possible, at least 50 cm from the room corners, no toe-in, with the listening position forming an equilateral triangle with the speakers. That's it. If your room is anything like my small room, there probably will be no bass boom audible anywhere within the room, much less at the listening position. You can add more low- and mid-bass by simply moving your chair back a bit toward the wall behind the listening position, but the bass still won't become boomy. Alternatively, for more bass in the bottom octave or two, just add electronic equalization, such as via Lyngdorf Room Perfect as I do.
You will then hear the best quality bass you've ever heard in your room, and that best quality extends at least all the way up past Middle C to at least 400 Hz. With the Larsen 9, the bass has superb power and definition in-room right on down to the low-20 Hz region, along with superb note and texture differentiation throughout the lower regions. You will not have heard cellos, bass viol, drums, tympani, tubas, trombones, bass voices--anything with significant note-playing power in the lower regions--sound so life-like.
Larsen bass sounds remarkably like it sounds in a large concert hall rather than the way all other speakers I've experienced sound in my small listening room. By comparison, in the lower ranges other speakers sound at least a bit thick, over-resonant, cloudy, murky, indistinct, with the differences among bass instruments at least a bit clouded and uncertain.
Some listeners hear this problem and run the other way, deciding to live without the full authority of having the 100 - 300 Hz "power range" at the proper level just to get rid of this murkiness. Instead, they accustom their ears to thinness, smallness, lack of weight, and the "toy-like" quality that sound deficient in the power range produces. Anything to get rid of the murk and the boom.
With the Larsens, no such horrible choice is necessary and it's just SO easy to get realistic sound throughout the lower ranges.
