Steve,
I was in your room, heard it, and liked it a lot. I don't doubt anything you say as far as measurements.
no room is flat nor would we want it to be perfectly flat. we want it to sound as good as it can and allow the music to be the way each of us might desire.
my point with Ron is only that if he starts out with a bunch of well intended curtains, he will never know where is is at....he will have delegated his musical flavor to the designer. sure; he can pull the curtains to the side and see what that does; but those curtains will still be absorbing sound even if they sit on the floor.
before he goes down the acoustical design road, (1)choose the gear and listen. (2)try some cheap things. (3)get a handle on a base line and (4)see what great things might be happening that he likes.
then step up into whatever direction that takes him where he wants to go with the knowledge of where he has been.
and in the meantime if he finds a sound that he likes he can use that reference to guide him.
I think Mike's advice is excellent and correct on all counts.
I will have Bonnie measure the room but I will not commission any acoustic treatment until I live with the system in the room for a while.
Best room acoustics heavily depend on the speaker, I've never heard Focals sound as good as they did in Boulder Amplifier's HEAVILY damped/absorptive room. They tried Wilsons in the same room and apparently they sounded bad, way too dead. Horns and controlled dispersion speakers are also much different vs conventional dynamic speakers. And there's a lot of leeway for personal preference.
I have a smaller room but have high ceilings, around 14ft, and it needed some absorption but much less that you might think, especially with my horn speakers.
Thank you for this idea, cjf. I am having trouble picturing what the triangle would look like.
The wall behind the listening position, which includes this column, has always been covered with 4' X 8' ASC-style sound absorption panels. My plan is simply to keep the sound panels covering the wall and the column and move the listening chair 4 feet away from the back wall.
Thank you very much for taking the time to create that rendering! I appreciate it!
And now I understand perfectly what you wrote originally!
My acoustic consultant suggested this curved absorber solution. I wonder how the sonic results would differ between the triangle and the curve?
(The room length is 25' not 29'.)
Ron,..you've had beautiful setups with great gear at each step of the way; it's also good to read about 'your journey' and microstrip's with all the pictures he posted. How is the project turning out for you? Do you have any experience with Vicoustics offerings or are you going a different route? Enjoy!
