The statement above is misleading or simply wrong:Feedback is a negative sonic trait required only where the speaker needs more drive. Better speakers allow for zero feedback sets to drive them to glory. If the speaker is not efficient enough it will require feedback or worse, big push pull or big SS amp.
1) feedback is not a negative trait if properly applied. It often is improperly applied FWIW. I can explain in more detail.
2) The drive (in the context of your statement this appears to be simply power) the speaker needs has nothing to do with feedback in the amp
3) The quality of the speaker has nothing to do with whether it can be used with amps without feedback. The design of the speaker is a different matter!
4) the efficiency of the speaker (see #2) has nothing to do with whether it will need an amp with feedback or not.
The simple fact is some speakers do not use the Voltage drive principles; instead use the older (pre-1956 or so) Power drive principles. The latter comprise about 1% of total speakers made; nearly all of them offered to a rarefied market in high end. Put another way the speaker has to be designed to be driven by an amp of higher output impedance (no feedback) in order to sound right. If the speaker has controls on the back for adjusting midrange and tweeter output levels then the speaker can be adjusted to match the Voltage or Power response of the amp to the speaker's impedance. That is how it was done in the old days prior to the adoption of the Voltage drive rules which were meant to improve plug and play (no controls to adjust to get it to sound right).
The 'anti SET rhetoric' is simply technical and engineering fact. I don't know of actual haters, nor any who are 'triggered' by SETs or some such. I personally feel its important to set the record straight (if you see what I did there) since so many people get, IMO, duped by them. If you are careful with selection you can find non-SET amps that sound better in every way, often for a fraction of the price and with more power.Beyond this though (and I usually keep quiet on these things) I also don’t just see how the discussion (once again) became hijacked by the weird random and compulsive anti SET rhetoric… never makes sense to me that SET haters are being triggered so constantly at seemingly every turn or most every topic to somehow drag the thread kicking and screaming back into let’s put the boot into what is just one niche of amplifier design… what are they ultimately threatened by and so aggressively and irrationally anti about, lord help us if they get involved in something that is actually vital or critical to world peace.
Fact can be a harsh mistress. SETs don't stand up well to engineering fact. I've outlined why many times. If you need/want further iteration I'm happy to help out.
