And yes, you hit the nail on the head with dynamic contrast! Increased reflections often behave like masking noise, obscuring quiet passages and subjectively reducing the overall dynamic range (typically 60–120 dB in music) – similar to a concert hall, where controlled, spectrally correct reflections (e.g., from the ceiling) preserve contrast, but diffuse wall reflections diminish it. Horns minimize these uncontrolled contributions, making them particularly advantageous in acoustically challenging rooms (e.g., with hard surfaces).
Are these pinnacle horn systems DIY or commercial offerings?Regarding commercial offerings, I completely agree with you. The reasons for this can certainly be elaborated on later. However, if we also consider private installations, there are already 4-5 systems in Japan alone that represent the pinnacle. Additionally, at least 3 in China, and easily 5 in Korea. A few more in Thailand. In Germany, I know of 4, and there are also a few good ones in the USA.
The reason why horns in the DIY sector have a certain advantage over commercial systems is pretty self-explanatory.
I’m fairly certain that Kedar could contribute something meaningful to this
Best regards,
S
To say a horn systems easy to setup because of 20-30% is not in my experience. I walked in to a AG dealer to hear Trio G3 and ready to put money on them. The dealer said they were setup perfectly. But all I heard is muddy and non coherent sound. It is so bad that it is the worst sound I hear from any type of speaker. However, I always hear great sound from Rockport speakers in shows or dealer’s room.
Can’t remember exactly as it was more than two years ago. The source was CD and the power amp was Burmester or itron. The dealer had all the models of AG. But the experience was so underwhelming. I walked away as soon as I finished listening Trio G3. I am not saying horn speakers do not sound great. I am just saying setting up horn speaker is easier because more of direct sound is not in my experience.What amps, source? And only the trios sounded muddy there? Did he have anything else?
sometimes with dealers changing stuff, it can be something as simple as forgetting to put a cable back on in the right direction, or not setting in this case the bass horn at the right cross point. I am not saying one should buy something that does not sound good, but if you hear it sounding good to your taste, replicating that at home will be much easier than a cone providing you have sufficient room size, and same set of electronics.Can’t remember exactly as it was more than two years ago. The source was CD and the power amp was Burmester or itron. The dealer had all the models of AG. But the experience was so underwhelming. I walked away as soon as I finished listening Trio G3. I am not saying horn speakers do not sound great. I am just saying setting up horn speaker is easier because more of direct sound is not in my experience.
Your claim that, based on your “experience,” it is not correct that horn loudspeakers are easier to install or less placement-critical than conventional loudspeakers is legitimate. The question I have is this: What is your experience based on? Does it solely stem from the one visit to an Avantgarde dealer you mentioned, or are there additional experiences you haven’t shared?To say a horn systems easy to setup because of 20-30% is not in my experience. I walked in to a AG dealer to hear Trio G3 and ready to put money on them. The dealer said they were setup perfectly. But all I heard is muddy and non coherent sound. It is so bad that it is the worst sound I hear from any type of speaker. However, I always hear great sound from Rockport speakers in shows or dealer’s room.
Let’s not derail the thread. But just want to say the dealer was with me during the one hour audition. The sound seems fine to him.Whilst not doubting your in room experience in the slightest , however something does seem to be anomalous , In that if it is one aspect of AG horns that one wouldn’t normally perceive it is muddy , quite the opposite . Did the whole audio spectrum sound as you describe or manifest itself more specifically e.g. mid bass / bass ?
Yes there was another horn audition. The dealer has several rooms of same brand but different models of horn speakers. Each room was big and big enough for large horn. The brand is German. I rather not disclose the brand name. He was vinyl fanatic. No digital sources in his rooms. The experience was not positive either but definitely more positive than Trio.Your claim that, based on your “experience,” it is not correct that horn loudspeakers are easier to install or less placement-critical than conventional loudspeakers is legitimate. The question I have is this: What is your experience based on? Does it solely stem from the one visit to an Avantgarde dealer you mentioned, or are there additional experiences you haven’t shared?
Regarding your listening experience that it sounded muffled, I’d like to note the following: If a horn loudspeaker doesn’t sound right, it’s not due to the horn concept itself but rather one or more potential errors that may have occurred. Don’t let it discourage you – such experiences are part of the learning process.
Best Regards S.
Corner horn bass can be operated horizontally or push them together to create a corner , using the floor and the wall behind it as the horn mouth.Great discussion. What are your thoughts on whether or not corner horns behave differently from conventional horn speakers? I imagine the directivity remains similar, but utilizing the front and side walls of the room for bass output may change things.
My room is almost square so the first reflection from the main horn is the opposite corner, where I imagine the sound gets scattered and reflected differently. The reflections are certainly delayed.
Like I said in my comment, these are private installations. But they are build with old commercial system parts.Old, but gold.Are these pinnacle horn systems DIY or commercial offerings?
The one in the picture is two WE 16a.Are these pinnacle horn systems DIY or commercial offerings?
It's the only original double 16A (usually a mono horn) supported by the Western Electric 597A tweeter. A Western Electric 12025 4-cell midhorn also equipped with 555 drivers attached just below the lower lip of each horn. The woofer system sitting just underneath the 16A is based on 2 x WE 4191 woofers plus 2 x Eltus reproductions of the 4181.The one in the picture is two WE 16a.
You mean it was made as a double, or he put 2 together?It's the only original double 16A
No, I mean two original WE16a in one installation. I know that Mr Chung has also a few, but not installed in one system yet.You mean it was made as a double, or he put 2 together?
Well tannoy blacks and silvers were also made as mono speakers so people are effectively playing two monos. Germany has a couple of installations of WE 16a (not double) that you would know with varied drivers going into 22a type subs, where people had to wait to find matching drivers.No, I mean two original WE16a in one installation. I know that Mr Chung has also a few, but not installed in one system yet.
This alone makes me prefer it over all other original WE installations. The owner decided to abandon the traditional WE approach and opted for a solution that is, from a technical perspective alone, superior. This relates to the ridiculous dogma that the 16A only sounds mono. Based on my experience, this is an utterly absurd claim.
That said, I think we should leave it at that, as this is about commercial horn loudspeakers that are accessible to anyone with the right budget.
Best Regards S.
