Since we are already about to argue with physics, I would like to come back to one of my posts from last week, which was ridiculed by this TAD user.
The Role of Direct Sound in Reducing Listening Fatigue: Why Horns Outperform Conventional
When listening to music or audio through loudspeakers, the experience can vary significantly. Some speakers feel fatiguing over long sessions, while others remain comfortable. Something, nearly every listener already experienced.
This treatise argues that a higher proportion of direct sound—the sound traveling straight from the speaker to the listener’s ears—makes it easier for the brain to process audio, leading to a clearer soundstage and less listening fatigue. Specifically, horns, particularly exponential horns, excel in delivering high direct sound, while conventional loudspeakers lose direct sound at lower frequencies, increasing mental effort. This is supported by psychoacoustic principles and audio engineering research.
Direct Sound and the Brain’s Processing
The human brain reconstructs a “soundstage”—a mental image of where sounds originate—using cues like the time difference between ears (Interaural Time Difference, ITD) and level differences (Interaural Level Difference, ILD). Direct sound delivers these cues clearly, as it arrives at the ears without interference from room reflections. A high direct sound share (e.g., 20–30% in the high-frequency range) allows the brain to easily localize instruments or voices, creating a vivid, stable soundstage with minimal effort.
Room sound (reflections from walls, ceilings, etc.) arrives slightly delayed, which distorts these signals. The brain must work harder to filter out reflections and reconstruct the soundstage, increasing listening effort. Over time, this effort leads to listening fatigue, causing discomfort or even headaches during prolonged listening sessions. Psychoacoustic studies confirm that clear direct sound reduces cognitive load, making listening more relaxing (Blauert, 1997). Notably,
Jens Blauert’s work btw has been instrumental in teaching me the most important aspects of horn development.
Horns, especially exponential horns, are designed to focus sound in a highly directional way, significantly increasing the direct sound component. Their geometric shape channels sound waves, particularly in the mid- and high-frequency ranges, where shorter wavelengths allow precise control. For example, horns can achieve 10–20 dB higher direct sound efficiency than conventional speakers, reducing room reflections (Tesmer, n.d.). This results in a clearer soundstage and less mental effort, making horns ideal for long, fatigue-free listening sessions.
However, for low frequencies (e.g., 20 Hz), horns require massive sizes (e.g., an 8-meter-long exponential horn with a 2.5x3-meter mouth for a 15” woofer) due to longer wavelengths, which limits their practicality for bass (Tesmer, n.d.). Still, their directivity in mid- and high-frequency ranges makes them superior for clear, effortless audio reproduction.
Conventional Loudspeakers: Losing Direct Sound at Lower Frequencies
Conventional loudspeakers, such as dynamic box speakers, struggle to maintain direct sound at lower frequencies. Bass frequencies have long wavelengths, causing sound to spread widely and diffract around objects, increasing room reflections. In typical rooms, measured at the listening position, direct sound can drop to as low as 2% in the bass range, though it may reach 20–30% in the high-frequency range where sound is more directional (Sengpiel Audio, n.d.). The dominance of room reflections forces the brain to work harder to separate direct sound from echoes, leading to greater listening fatigue over time.
Conclusion
A higher direct sound share, as achieved by horns, simplifies the brain’s task of reconstructing a soundstage, reducing listening effort and fatigue. Conventional loudspeakers, with less direct sound at lower frequencies due to room reflections, demand more mental processing, making them more fatiguing over time. Horns, with their superior directivity, offer a clearer, more immersive experience, proving why they are less taxing for long listening sessions. This theory is grounded in psychoacoustics and audio engineering, as evidenced by research from TU Berlin and Sengpiel Audio.
Resources from Sengpiel Audio, such as “Direktschall - Deckenreflexionen und Wandreflexionen,” explain how direct sound diminishes with distance and frequency, with reflections overtaking in reverberant spaces (Sengpiel Audio, n.d.). This aligns with why conventional speakers can feel more fatiguing during extended listening.
Evidence from Research
Academic and practical sources support this theory:
• TU Berlin’s Audio Communication Group: A thesis by Nils Tesmer explores horn loudspeakers’ ability to enhance direct sound efficiency, improving sound radiation control and reducing room interference (Tesmer, n.d., available via
DepositOnce).
• Sengpiel Audio Resources: The document “Direktschall - Deckenreflexionen und Wandreflexionen” details how direct sound decreases in typical rooms, especially for low frequencies, increasing the role of reflections (available at
http://www.sengpielaudio.com/DirektschallUndDeckenreflexionen.pdf).
• Psychoacoustics: Jens Blauert’s work on spatial hearing highlights how clear direct sound improves binaural processing, reducing cognitive effort (Blauert, 1997).
Additionally, TU Berlin’s exercise collections on acoustics (e.g., “Nahfeld und Fernfeld” and “Diffuses Schallfeld” at
https://sengpielaudio.com/AufgabensammlungAudiokommunikation.htm) confirm that direct sound dominates in controlled setups, while diffuse fields in typical rooms challenge the brain’s processing.
Best Regards S.
