Ok guys they are in. Playing for only 3 hours and on they are. Not much I can say but... Oh my... They are HUGE,,,
You are indeed a lucky man! A HUGE congratulations Eli. I am happy for you.
Ok guys so I finally did it.. and ordered the R1s... I am taking delivery either tomorrow or day after, and they will remove the CR1s.
As happy as I was with the sound of the CR1s, I felt I missed some of the things only big speakers can do in terms of macro dynamics and weight of presentation. Otherwise the CR1s were perfect. Anyway, before I got into TAD, I had in mind buying a big speaker so I guess I have done something closer to my first idea... We will see. I have been assured they should work fine in my room if placing them properly. WIll keep you posted.
This is a mixed bag. Designing a product from the ground up is difficult. It is nigh impossible to optimize every aspect of the design. Inevitably cost cutting and and minimization creep in. New materials emerge that makes things better. That is usually good.
Depending it on how it plays out the intiail run could have involvled considerable overkill. They may later decide they can get by with lesser quality materails or lesser tolerances. You often see this disclaimer(Specs and and materailas may change without notice.) You can somtimes detect how many models were made. Many start with the S/N? 001. If you have pair #2&4. It is unlikely any siginificant changes were made that quickly.
If you auditioned a pair that was made close to the ones you purchased you should be okay.
Just came back from running. Got into the listening room to check how they were doing, and one thought comes to mind I want to share... Man, day are BIG.... They have been on all day. Will listen a bit later to see how they evolve.
