I have the CR-1s and have now driven them with Devialet, D'Agostino, Sanders Magtech, Halcro DM58 and presently with Soulution 710. Most of those amps are in the 250 - 350W 4 ohm territory (give or take), except the Magtech which achieves around 900W into 4 ohms. The CR-1s are stunningly dynamic (obviously "big motors") and benefit from a powerful amplifier - or at least one that can source the current needed to carry off the transients. TADs own M600 is supposed to be ideal at 600W. After that it is flavours in my experience, but do beware with the CR-1s, they expose all, and any hardness in the sound is not good. Personally I'm a bit stuck as I like realism, and I don't like artificial sweetness at all. The Devialet is pretty good but I feel needs more current and a copper cable to calm it on the CR-1s - too bad mine are rectangular silver - any copper I've tried subtract from the information. The Momentums for me were just a little too warm and interpretative (but I seem to be the only person in the world who thinks this). Bass was not ultimately as tight/extended as the CR-1s can do and treble seemed rolled off. Voices were wonderful - but .... I wasn't convinced this was the signal I was feeding into the amplifier (personally I found ASR similar in this respect though I didn't have the CR-1s then). The Magtech is a good match and I've enjoyed it for many hours - the sheer dynamics are fun. But ultimately I found it not as resolving as the super amps. A friend's Halcro's were stunning, though probably too edgy overall for even my tastes on these speakers - wonderful tops; copper power cables helped. The Soulution 710 is a recent addition and seems to be finally a match in quality at least for the CR-1. There is wonderful clarity in the bass, mids, treble and voice and instruments seem quite natural. The differing characters of cymbals are rendered well. Spatial detail is a step up on the other amplifiers (except the Halcro). From my reading I gather the Soulution 500 series are a step on the warmer side and this would probably be a good thing in most people's views. Tonally the Magtech, Halcro and Soulution were very similar - I think just straight down the middle. I'd say the Halcros were the most obviously resolving, the Soulution just a little creamier (helpful with CR-1, voices benefiting in particular). The TADs would have to be described as forward, and their amplifiers on the other hand are reviewed as a little reticent sometimes - I believe there is a degree of matching there. In the end the CR-1s are stunning speakers quite able to do things other larger speakers can only dream of. But they are very unforgiving and can be incessant in some ways (reminiscent of Yamaha NS1000s maybe?), so I guess be careful what you wish for - you may get it
) I had the Burmester 911 before the TADs arrived and I can't imagine it being a good match - too much brightness in my experience- they do not need a bright amp. BTW, the Magtech power was pretty much unlimited on the CR-1s and they can certainly go very loud before compression is noticeable - most of the time this is irrelevant, but certainly current delivery
is needed. The Devialet runs out on this I think, the Magtech does not, and the Soulution, despite being much lower powered, shows no compression until it meets its voltage limits (albeit at a much lower level than the Magtech). In other words for normal listening Soulution provides the dynamic power that lets the speakers shine. But if I had a choice of Soulution sound and Magtech power (.....and could afford it - M600s anyone?) I'd go for it.
So ..... I guess all this just says the CR-1s revel with a bit of power and I think the Soulution 500 series would be a worthy match if you are a fan of unadorned sound. Another I thought might work well was Constellation Centaur but maybe it's early days on those. I haven't had the opportunity to try TAD, Dartzeel or Viola sorry.
