Principle: 3-Way, high sensitivity, symmetrical bass reflex loudspeaker
Driver: 1 pcs. Göbel® High End proprietary long-throw Bass chassis (12 inch), 1 pcs. Göbel® High End proprietary midrange chassis (8 inch), significantly improved Mundorf AMT with massive aluminum wave guide
Housing: Acoustically optimized, constraint layer damping, tropical room proof, resin bounded composite board with max. 75 mm thickness
Standard finish: Real piano lacquer black, aluminum parts in black ultra Matt soft touch with silver colored high lights. Any finish is possible on customer request!
Sensitivity: 92 dB / 1W / 1m
Frequency response: 21 - 28.000 Hz (-3dB)
Impedance: 4 Ohm
Dimensions: 118 cm (H) x 41 cm (W) x 72 cm (D)
Weight: 150 kg without packaging
