What's that Jarek?
Does it come w a ton of concrete mix to be installed under it?
Sth much more subtle
What's that Jarek?
Hi Mike, as you know, there are different prices on different streets; it is patently so in audio.
...AF1 streets, it is the low $40k USD to mid $60k USD; depending, of course, on the street.
I would guess that it is the same for the AS, some streets are at different prices...
So, Mike, if you are pricing the AS at the AF1 price, that would be also in the mid $40k USD to mid $60k price range?
Steve, you have made some very good points regarding the AF Zero, interesting machine and designer...I love his designs starting with the big Micro Seiki machines... I love David too...
Cheers!
ALF
They haven't replaced the Vibraplane with a Stacore, have they?!
Even yr platforms would struggle w these weights.
Jarek, I'm out of such uber heavy tt rigs myself. I'm listening in an attic roof space w suspended floor.
My money is on the new intended Technics SP10R as my final final tt purchase if my current analog doesn't match up to the server/dac I'm planning to buy next yr.
Cheers!
ALF
Dear Khun Tang,
I use a thin leather mat but you know how they are, too thin and sound is harsh too thick it's dead and dark, you need just right! Recently I found another mat material that's just as tonally rich, balanced and alive as the leather mat but a with very different presentation, really like adding a new arm and cartridge. Both are included with the table, one can look at it as having 8 arms and cartridges on the same table instead of 4 by switching mats. Metal mats or different upper platters aren't recommended they interfere with the purity of the sound and only add coloration.
david
David, are you and Tang talking about the same thing? I thought Tang was suggesting a thin layer of leather under the turntable plinth or steel plate and above the rack support. It seems you are talking about a record mat between the LP and the platter.
I am interested in learning a bit more about the belt. What is it made of? Is it compliant? Does the amount of "free" belt not wrapped around or in contact with the drive pulley or platter matter? I presume it takes a while for the platter to get up to speed, but I really don't know. I read Marc write that it is a high torque motor. Is this true or is it a low/med torque motor that relies on the inertia of the massive platter to keep accurate and consistent speed. I assume all of these things were thoroughly investigated in the 70s when the original AS table was designed but I am curious to learn what the details actually are.
Just to put all this conjecture to rest; AS isn't a commercial product and there's not going to be a production run, it's limited only to this one very small individually hand machined lot. Reference to AF-1's retail price was just an indicator that it's in the 6 figures, those who got one understood this and are the only ones who know the actual cost. Further, aside from floatation principle there's no similarity conceptually, intellectually, physically, mechanically and certainly sonically between AS and Techdas turntables. I have my AF1 too!
david
Let me help hyping this tt.
"You never actually own an American Sound. You merely look after it for the next generation."
Now Patek Philippe will sue me.
Tang
Brilliant. I was just mentioning to David tonight that this TT should last me until the pine box..I'm 55 now.
Hahaha! Great, David!![]()
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
