Do you sell just a tone arm and pump?
How much pressure does the arm need ?Looks nice.
Where is the pump hose.
How do you route the tone arm cable.
Do you have cable options.
From 0.3 bar and up.This is the case with the Holbo mk2 turntable. Only the tonearm will have a stronger compressor with a pressure of approx. 1 bar.How much pressure does the arm need ?
I think you can see the air connector and the phono DIN 5 pole cable connector.Looks nice.
Looks like you can adjust VTA during playback, is that correct ?I think you can see the air connector and the phono DIN 5 pole cable connector.
Yes, correct.Looks like you can adjust VTA during playback, is that correct ?
The Holbo mk2 air pump is very quiet, almost inaudible and can be used in the same room as a turntable. To hear it working, you need to get very close to your ear.Hello Bostjan,
How noisy is the air pump? Must it be located in a different room than the room in which the turntable is located?
Thank you Graham.Here is one of my demonstration turntables, a Holbo II with a ZYX Omega cartridge mounted. I have to say this is such a lovely turntable, not only from its ability to provide excellent sound quality, but also it is lovely to use, as well as punching well above its weight from a cost/performance perspective. Latterly I have been using it with the wonderful ZYX Ultimate Dynamic and Ultimate Exceed Dynamic cartridges.
This exceptional turntable really does give a beautifully well balanced sound and is extremely easy and very precise to set up for maximum performance and is a total bargain at the price.
Hello Graham!Here is one of my demonstration turntables, a Holbo II with a ZYX Omega cartridge mounted. I have to say this is such a lovely turntable, not only from its ability to provide excellent sound quality, but also it is lovely to use, as well as punching well above its weight from a cost/performance perspective. Latterly, I have been using it with the wonderful ZYX Ultimate Dynamic and Ultimate Exceed Dynamic cartridges.
Hi Ron,Hello Graham!
If I remember correctly you demoed for me tube amplifiers on Analysis Audio planars!
The Holbo looks great in those photos! It's a relatively simple and very modestly priced way to get linear-tracking and air bearing vinyl playback. I also like ZYC cartridges.
Yes, the Trons.Hi Ron,
Yes, it was the tube amplifier demo with the Cessaro Liszt horns. I seem to recall you came with Marc and it was a nice afternoon visit. I agree, the Holbo is very simple and a very affordable and effective way to get an air bearing turntable and linear tracking tonearm, plus the ZYX cartridges are also a very good match for the Holbo too.
Probably Ked.Yes, the Trons.
I auditioned the Analysis Audio with somebody else in the English countryside. I'm sure Marc would remember.
