My Wilson Journey...
Some pics...
Can't wait to hear it, Steve!
Reactions: slowGEEZR
Power Center are all Essential Sound Products Gerald Veasley Signature Music Cord Pro cables.
ESP Power cables are excellent and highly underappreciated. I have used the PRO-ES version of the ESP Victor Wootan Signature cables (identical to the Gerald Veasley Signatures) for many years. They are stellar performers at a very affordable price. They out performed a 10K Tara Labs PC (yes, seriously). It would be hard to find a better bass cable. If there were such an obvious alternative, Wooten and Veasley and countless studios would be using them!!
I thought I'd update my Wilson journey. I still have the WP8s, as the sound has improved with every update I've made! Here is my current setup with pictures and descriptions. I'll be happy to answer any questions.
  • GEAR: Wilson Audio Watt Puppy 8 speakers with upgraded Carmen Red paint. They are using the IsoAcoustics Gaia I isolation feet. SVS SB 4000 subs. The subs are sitting on IsoAcoustics Aperta Sub XL stands. Turntables: Currently only using the Luxman PD 191A with its 10" LTA-710 tonearm. This tonearm is a joint development of Luxman and SAEC. I am awaiting a new stand and phono amp for my main turntable, a modified by me TTW GEM V2. It has a 42lb copper platter and a heavily modified Jelco 750 tonearm. I will place this table and its rack and phono pre against the wall to the left of the seating position. The phono cartridge currently in use by the Luxman is an Ortofon Cadenza Bronze. Various other cartridges include: Hana SL and Hana ML, Clearaudio Virtuoso, Soundsmith The Voice. I also have ten different headshells, which I rotate from time to time. The phono amp is the BAT VK-P5, which is sitting on IsoAcoustics Orea Series isolation feet. The corresponding SUT is by K&K, who by the way, has retired. The preamp is the Pass Labs XP-20 with the Tubulus umbilical replacing the standard connection to its power supply. Quite an upgrade. The power amps are Pass Labs XA 100.5 mono blocs. They have proven to be excellent with the Wilsons, IMO. Digital: Innuos ZENith mk3 Server/Streamer, with 4 TB SSD storage. Innuos Phoenix USB Reclocker. Ayre QB-9 Twenty DAC also sits on IsoAcoustics Orea series isolation feet. Sansui TU - 919 Tuner. All gear except powered subs and the mono blocs are connected to the PS Audio Power Plant Premier. The amps are connected to a PS Audio Duet Power Center, which has a Shunyata Power Defender plugged in. There is another Shunyata Power Defender and a PS Audio Noise Harvester plugged into the same power duplex as my subs.
    Cables: Speaker cables are MG Audio Designs Planus III foil cables. I have tried five different speaker cables with my Wilsons and these are by far the best sounding, to me. All interconnects are Mogami Neglex 2534 Microphone cable except: Audioquest silver cable from preamp to amps, Straightwire Maestro from SUT to phono pre. The turntable has its own cable to the SUT. I use Morrow SUB 4 cables to the subs, Morrow Audio Reference USB cables (2) and RW System CAT 6 ethernet cable. I also have two Morrow Audio Ethernet CAT8 cables on the ready for when I add the Innous Phoenix Net to the system. The power cables on the subs are regular cables and the power cables on the mono blocs and Power Center are all Essential Sound Products Gerald Veasley Signature Music Cord Pro cables. I use a Shunyata Anaconda Helix Alpha power cord to the preamp.
    Room: The room is 19'6" wide x 30'10" long x 8'6" high. There is an additional 3'2" that extends past the left side of the rear of the bar. One of the rooms back there is my record room. The Wilson's tweeters are 62" from the front wall, 58 and 3/4" from the side walls and 163" from ear position sitting up and 165" when reclining. Ear normal sitting height is 1 inch above tweeter and reclining is 1 inch below.
    Acoustic Treatments: Dead center on the front wall are two 4' x 8' Poly diffusers that I made. I used two sheets of 1/8 inch Peg board. I used T-Slot framing rails and 1" x 3" x 8' boards to screw the peg boards into after inserting into slots on the T-Slot rails. To get the boards to sit perfectly together, I used twisted wire to crimp them together. 36 joins were needed, but the end result was a perfect fit, no over or under hang! Then covered. On each side of that diffuser are four 1" thick GIK Wood Slot Acoustic Panels. Due to soffit, some cutting was required. In the front corners are two GIK Tri Trap Corner Bass Traps. I have two more of them, plus two GIK Soffit bass traps, but they are not required in this room. I'm currently running the subs at -11db! Atop the corner traps are home made diffusors, made by a very good friend of mine. The white diffusors, are twelve Auralex T'Fusor Diffusers. Next are the four GIK 2A Alpha Pro Series 2" Panel Diffuser/Absorbers. Moving towards the rear of the room is one GIK 242 acoustic panel, to absorb any reflection off of the wall by the exit double doors. In the rear of the room are some home made slap echo diffusers, which eliminated the barely perceptible slap echo in this large room. There is also one above the 242. These were also made by my friend. I currently have installed four GIK 242 acoustic panels on the ceiling. Oh, I also intermittently use another 2A Alpha Pro Panel a few feet behind the main listening chair, leaned against the front of the bar. Future acoustic work will include putting two GIK Evolution Poly Fusers on the doors to the listening position's right side and two on the corresponding window to the left. I have two of them and am awaiting the other two.
    Pictures in my next post.
Fantastic reading! One minor question...I see you use "PS Audio Noise Harvester plugged into the same power duplex as my subs."
What was this for? Ground loop hum which I understand is common with subs? Just curious. Thanks!
Agreed. They were excellent value and are very well constructed.
I'm not using it as a ground loop hum buster, just as a line conditioner. I had it, as well as the two Shunyata plugin conditioners, so I figured I should use them. Also, it is plugged into the right channel sub outlet, while one of the Shunyatas is plugged into the left channel sub outlet.
Outstanding set-up. So happy to see that you have retained your WPs. I have been happy with my WP7s for over 15 years, as well. They are paired with Concert Fidelity electronics. The next update is a good rack from Live Vibe Audio over the summer, along with an Accuphase DP-770 CD player and an EMM Labs NS1 streamer. Thanks for sharing those beautiful photos. Many good ideas for replication. Basile
looks very nice!
If you have already uploaded your previous setups with Wilson speakers, then I would be happy to share as well
me, about 4 years ago, with the previous setup,
An attempt to combine a very serious and high-quality cinema and a high-quality stereo setup.
Music
wilson Maxx 2's
karan reference set (KAS600+Ref KAL3)
MSB The Analog Dac
Cinena
Trinnov alt16 Sorround Processor
oppo bdp105 EVS modified + Zidoo
Wilson watch center (twitter upgraded to watch 3)
svs ultra16 sub
lexicon power 7ch
IsoTek super titan
Solid-teck ROS's
transparent reference XLs cables
and more...
I like those in yellow! Even if our Wilsons are old, they still show improvement with every advance in acoustical treatments and gear, in my experience. I came from Martin Logans to the Wilsons and thought I had made a mistake, but as I improved my gear and treatments, it became apparent that the problem was not with the Wilsons! Enjoy your gear updates!
looks very nice!
Music
wilson Maxx 2's
MSB The Analog Dac
Cinena
svs ultra16 sub
lexicon power 7ch
IsoTek super titan
Solid-teck ROS's
and more...
Wow! Very nice!
