Here words are simply thrown into the room again. Cliiping means that the amplifier no longer correctly amplifies the sine signal from the input, for example. The sine curve is cut at the upper end, which initially produces no additional distortions. Only if you turn the volume up to 1.28 times the normal output power of the amplifier then you produces distortion of 10%.
With more power than the speaker can handle, it doesn't get any louder, it just distorts, heats and destroys even more! This is called compression (see picture).
Compression range: Here the speaker no longer becomes louder in proportion to the increase in power. The causes are mechanical limitations and increasing resistance depending on temperature. The additional power is therefore used extremely ineffectively! Compression in dB is the distance between the real and theoretical volume.
I don't know the maximum value of the spl for the ribbon speakers. But they definitely reach their limit earlier than cone speakers at lower frequencies.
