Ron - WOWlooks and I'm sure! it sounds distinctive amazing!
congratulations
A very interesting amplifier! What is the output in EL34 mode?when you want a special sound audio sculpture equilibre (france)amp 2x el 34 runs in triode 2x kt 99 in pentode mode at the same time best out both worldsView attachment 118562
Is this a predecessor to the Audio Aero Capitols amp, which did the same thing? Looks similar from the layout too. Audio Aero also made a very interesting SET/P monos. They used a 211 and an 813 in pentode in parallel...very unusual. They also had one with EL-34 and FET in parallel..when you want a special sound audio sculpture equilibre (france)amp 2x el 34 runs in triode 2x kt 99 in pentode mode at the same time best out both worldsView attachment 118562
It is running the EL-34S and KT-90s in parallel but the 34s in triode and the 90s tetrode. It is not switchable between output tubes... They work together.A very interesting amplifier! What is the output in EL34 mode?
View attachment 117470The ribbon on the Pendragon is an upgraded animal from the previous BG 75 incher. This is the sensitivity spec for the Pendragon with the passive crossover element. I presume stronger magnets, better high frequency dispersion, and higher sensitivity. Pendragon does augment with the additional tweeter element, so that bat audiophiles are not comprimised.
Lola, unfortunately, is not feeling well, so she was uninterested in a careful listening session.What did the dog say?
Yes, Lola saves us a lot of money on napkins....whoah! With a cursory look I honestly thought you had one of those shearling throws on your chair. What an amazing coat!
I don't know that, I just know that there is a closed version of the equilibre amp called the S 40 atmosphere from audio sculpture.Is this a predecessor to the Audio Aero Capitols amp, which did the same thing? Looks similar from the layout too. Audio Aero also made a very interesting SET/P monos. They used a 211 and an 813 in pentode in parallel...very unusual. They also had one with EL-34 and FET in parallel..
Ron, did you play your new turntable for your father-in-law and brother-in-law?
2x60 watt class A (el34+kt99)sounds like 100watt working is really iron pig .drives apogee speaker easy like fingersnapA very interesting amplifier! What is the output in EL34 mode?
But, does Lola have a surcharge for foxtail scrubbers?Yes, Lola saves us a lot of money on napkins.
