Romaz Anas please correct me if I am wrong.
if the mass of conductor makes so big difference the effect of the power cable should be much bigger
Than a fuse with the same treatment.
Another important question with the placement of my amps in a cabinet area. Are the Ultimate speaker cables bendable with their oversized thickness? I would need to bend the cable probably 90 degrees to make them fit.
Hi Willgolf, What you need to know is the radius of the bendAnother important question with the placement of my amps in a cabinet area. Are the Ultimate speaker cables bendable with their oversized thickness? I would need to bend the cable probably 90 degrees to make them fit.
I don’t think I remembered this but I just checked and my XLR was oriented correctly. Thanks!For those new to the QSA world, the QSA Lanedri cables are directional. The white -half- arrow on the left to the logo indicates the direction from source to destionation.
Can you please elaborate what you mean? ThxHi Willgolf, What you need to know is the radius of the bend
I think he means what is the radius of your turn when the cable goes 90 degrees. Is the radius 2 inches or 2 centimeters? Obviously, the tighter the turn, the tougher to make the cable go that way.Can you please elaborate what you mean? Thx
I would say that it takes about three weeks to get to full performance. I lost the ability to determine if they improved further beyond that as I was helping to test the latest noise shaping in PGGB 256. Together I am hearing the most significant upgrade in terms of making voices and instruments sound like the real thing. This upgrade didn’t even cost me that much once I factor in the proceeds from selling my previous cables. Crazy bang for the buck.know you reported the upgrate in SQ before.
was thete any other SQ change over longer time ?
Or should we estimate that after about a week we will get full performance ?
Yes absolutely.Still happy with the final result ?
I will be receiving a Gamma Infinity power cord in this next batch. After that I will likely to snag a few more.getting more cables or stopping where you are ?
I thought I was just lucky as far as the orientation. Haha.Unlike RCAs, XLRs can only go in one direction.
a 90 degree bend is 1/4 of a circle. So what is the smallest circle you can form with the cable before you start to damage its conductors, dielectric and screen. If the radius of the circle is say 10cm, then your 90 degree bend will take 2 x 3.142 x 10 x 0.25 = 16cm of cable (2xPixRx0.25)Can you please elaborate what you mean? Thx
I have 7 inches between the amp and the back wall. If I am using spades and turn them sideways, I should be able to accommodate the speaker cables without bending much at all. Now I just need to know the thickness of the whole cable as I might need to make the hole in the wall larger. Thxa 90 degree bend is 1/4 of a circle. So what is the smallest circle you can form with the cable before you start to damage its conductors, dielectric and screen. If the radius of the circle is say 10cm, then your 90 degree bend will take 2 x 3.142 x 10 x 0.25 = 16cm of cable (2xPixRx0.25)
Yes, but yet many RCAs are directional - they use balanced wire and the shield ground is just connected at one extreme.
This was the first set of XLRs that I’ve used in over two decades. I had realized when arrived that I could only install them one way but forgot all about it. So your reminder was appreciated.My point was that you can physically connect RCA cables either way but you can’t with XLRs.
I know you reported the upgrate in SQ before.
