OK, so this is power filtering.You should learn microspeak. It cleans up the power so you don't need power cable to do it.
EDIT: Actually let's leave it at that. It is otherwise not relevant to cables.
By the way, could you elaborate on this, please? I'm not sure what you mean by "highly filtered Lamms".
to start .........What is a "biased subjective opinion"? And what's the alternative? What does it have to do with the cost of the gear in question? Are your opinions of what your own gear/system sounds like biased? Subjective? Is there such a thing as an objective opinion? A subjective unbiased opinion? Not clear what point you are trying to make.
to start .........
So, my subjective opinion is first and foremost rooted in objective facts to which I believe in. As for trying other cabling, yes, years back I experimented with the likes of MIT, Shunyata to name a few and while they performed admirably they did so no better than what I have now. To that I realized that real benefits are best found with maximizing ones speakers and room interactions for optimal sound.
I fully understand that in the end this is a hobby. One in which you're free to do what you like, so for me I'd rather listen to music than cables !
very nice, enjoy your wire ...........A very limited view on subjective and objective, ignoring how they can merge. Most time people use the words objective as being synomymous of technical or measurement, something it is not completely true.
Tim,
Can we know what cables you are currently using?
This is an interesting question. Does it matter, and if so, why? As soon as one mentions a brand, many will imagine all sorts of things. I know I do based on what I have heard in cable comparisons in my own system and elsewhere. Most wires that I have heard add a very distinct signature which often influences strongly the sound of the system. As Tima writes, it is hard to know what the wires do until you change them.
Except for my SME NOS phono cables and Ching Cheng power cords, I don't even know what cables are in my system, so I could not even answer the question you asked Tim if I wanted to. My wires came with the gear when it was shipped to me. I had a different IC from preamp to amp because it was quite long. It sounded great in my old system, and I thought pretty good in my new system. DDK came to fine tune the new system and listened. He then inserted a new long IC. The sound instantly became more balanced, and I heard more information presented naturally. We both knew that cable sounded right. Importantly, it did not have that distinct signature that I so often associate with so many wires I've heard. My wires are cheap, and likely no longer readily available.
People keep what sounds right to them in their systems. Exposure and keeping an open mind helped me a lot.
Yeah! It sure worked for me on that evening. I've kept the settings stored in my crossover, so some evening when I'm feeling brave I'll try it again. I don't know why but this sort of thing makes me a little nervous. I like measurements that make sense. I can't measure my emotions.This sounds like highly desirable music "magic" to me!
Yes. But this type of filtering, using several inductors in series with power and tuned sections will interfere with many types of power cables.
But he didn't ask you, Peter. He asked Tim. Most people know what cables they have in their system. Your posts are becoming increasingly obsequious.
I would not say that Lamm electronics 'interfere' with power cables, rather as is the case with all electronics and signal and power cables, there is matching for best result.
Surely careful matching of any cables is always needed. However most manufacturers avoid such specific filtration and readers of reviews should know about it.
The fact is that Lamm users seem to be a group that does not appreciate elaborate and/or expensive power cables and often criticize such approach. Just trying to find a reason for it in a thread about cables.
IME it has nothing to do with Lamm but with personal choices and experience. Also IME adudiophile & non- audiophile wires and specially power cords don’t change character with system. Their signature and SQ remains the same in all systems and this is something I’ve paid a lot of attention to over 3 decades. I’ve been recommending CC power cords since 2001, there are many more happy CC users than the few who report here and 99.9% don’t use Lamm electronics. I’ve successfully installed them in a variety of systems myself replacing all kinds of audiophile power cords. More than even personal preference it all depended on how far the audiophile HiFi rabbit hole one was.Surely careful matching of any cables is always needed. However most manufacturers avoid such specific filtration and readers of reviews should know about it.
The filter is great but unfortunately it doesn’t make the electronics impervious to mains quality or the sins of power cords.View attachment 87576
Lamm's are fitted with elaborate industrial power supply filters. From their web site : "All LAMM models are equipped with internally built power line filters of high quality. " See this photo of the ML3 power supply:
Yes. But this type of filtering, using several inductors in series with power and tuned sections will interfere with many types of power cables. IMHO it is why opinions on the power cables formulated with Lamm equipment are particular to such equipment and probably can not be generalized. BTW, there are more cases of such behavior - I only referred to Lamm because I own them.
Ciao a tutti .
è veramente difficile osare una risposta.
ciò che conta "secondo me" e riuscire a mettere a punto un sistema che risulti essere il più aderente possibile all'evento reale .
se questo avviene allora non è un problema in quanto il vero fine dell'hi-fi è quello di risultare credibile ed evocativo .
ps
chiedo scusa se non scrivo in inglese ma sono troppo scarso .
No, Francisco. CLC filtering and RFI modules are not uncommon and don't interfere with power cables. There are two inexpensive Hammond chokes and a quad of electrolytic caps in the PSU you posted. I don't understand what you could possibly mean by "interfering".
I (or anyone here, as far as I read) never said that there was no difference, just that the sonic signature could be atypical using Lamm gear. I see it in my system, YMMV.If there was no audible difference then why is there a preference for a specific cable? Lamm folks in this forum are but a clique and have certainly found what they like through contact with @ddk . If it works, go with it.
