Why?The notion that antique wire used as interconnects or speaker cables, Ching Cheng power cords, etc are not tuning the sound or are somehow more transparent to the native sound of the connected components is silly.
Omission is by definition a sin of commission and if that was the case CC would never be in any said “particular” systems with or without Master Signatures . High resolution natural sound is the cornerstone of some “particular” systems they simply don’t need artificial additives.They're absolutely colored tuning devices. It's just that their sins of omission are sometimes preferable to the sins of commission committed by many alternatives. This is particularly true in particular systems featuring Master Signature front ends where they are commonly favored.
The coloration is there, David. It's just of a different type. I don't agree with the premise that these cables are lower in coloration nor higher in resolution. I do agree that they're economical, but in the sense that you could achieve similar coloration with higher priced audiophile alternatives.
The Master Sig has certain sonic qualities that need to be tamed, and is lacking in areas thst need to be supplemented for the final result emitted from the speakers to sound balanced overall. It has many other great sonic qualities as well, but I'm not focusing on them here. Most people consider the Wavestream Kinetics archival phono stage to be a neutral device. I'm familiar with it and have many high quality digitized recordings from it. If we recorded Master Sig needle drops through this archival phono (even with a CC cord!) then we'd hear excessive and shrill high frequency energy and a lean overall character that is just endemic to that cartridge. The former quality likely owing in part to the fancy gold transducer coil wire. So, partnering with subdued CC cords, laid back phono stages (e.g. LP2 1), richer sounding interconnect wire and warm (e.g. 6C33C) amplifiers is no accident. It's a valid, deliberate, and well-informed approach. But it's not maintaining neutrality nor transparency to the source. *Removing* those layers, and their strong influence, would show that. And the cables and cords are an important part of that equation.
Hi Brian,The coloration is there, David. It's just of a different type. I don't agree with the premise that these cables are lower in coloration nor higher in resolution. I do agree that they're economical, but in the sense that you could achieve similar coloration with higher priced audiophile alternatives.
Any audiophile who can discern cable differences based on phone recordings / you tube vids will be the " GOAT"
What you would do with $25K has nothing to do with the role and importance of cables in “getting the matchups right”. Again, since you can only know whether you have “the basics right” via cables it doesn’t make sense to try to separate them from the other components in a system and diminish their role or value. You certainly don’t have to spend $25K to get cables that promote system synergy. On the other hand if you’ve never tried $25K (i.,e., top tier) cables you are not in a position to comment on their potential contribution.First get the basics : components/ match ups right .
if then they still wanna fool around with cables so be it .
25 K spend on better speakers / amps / sources makes much more sense to me .
Or a better room , cables would be the last on my mind
Im never gonna spend 25 k on cables, id rather buy a aprillia RSV 4 for that money , cant beat that one soundwise.
Or design a new speakermodel much more fun then cableswapping.
For 25 k i can probably buy also all tapes available from acoustic sounds / tape project.
And isnt " Music " where this whole thing is about
Although I dislike your style - finding something silly in an hobby ruled by subjective preference IMHO is not a good way to debate a subject such as cables - I agree with your main idea.
Ching Cheng a good power cable for the highly filtered Lamm's,
By the way, could you elaborate on this, please? I'm not sure what you mean by "highly filtered Lamms".
This is good saving.
LMAO, so someone who spends 25k and makes nothing more than a biased subjective opinion is ?On the other hand if you’ve never tried $25K (i.,e., top tier) cables you are not in a position to comment on their potential contribution.
What is a "biased subjective opinion"? And what's the alternative? What does it have to do with the cost of the gear in question? Are your opinions of what your own gear/system sounds like biased? Subjective? Is there such a thing as an objective opinion? A subjective unbiased opinion? Not clear what point you are trying to make.LMAO, so someone who spends 25k and makes nothing more than a biased subjective opinion is ?
