Maybe; but unless I have CMS or HRS amp stands right next to the Tana/Herzans I will never have a direct comparison and a clear answer.
Ron, these will invariably affect the sound. Might be for the better, or it might not be. If it were me, I would try to listen to the effect of these platforms under amplifiers before you commit to spending the money.
I do not like the term "voiced" either. Some designers, I've talk to chuckle at this notion as well.This is a perfectly reasonable and practical view.
Do you think components are designed to sound the way the designer wishes (for some reason I find the term "voiced" to be annoying, so I am avoiding using it here) assuming a median level of ambient vibration in homes?
Jim White told me that he feels nothing bad sonically could come from placing an Io on a Herzan. If I remember correctly, David agreed with this, too.
I will be able to tell you the difference of the Io on a HRS M3x2 versus, just 2" HRS Nimbus feet versus the Io just on a Finite Elemente stand.
I can tell you that the 2" Nimbus feet system had a profound positive effect on articulation and bass quality when I first used them with the Io.
I bought my Brinkmann Balance with its own M3x2 so the spare one will go under the Io now and I will perform those experiments over the holidays.
In my listening room (wood floor), I had the opportunity to switch between
HRS M3X (80 x 60cm, 8 feets) (spring)
on the ground
CMS MAXXUM (80 x 55cm) (Gel type?)
Rack and Platform
Accurion i4L (70cm x 55cm) (active)
on CMS Olympus Amp Stand
My amp that time was the VTL S 400, which has the same chassis, that VTL Siegfried.
Findings:
HRS M3X
clean and structured, good resolution, a little bit dry
With Heavy Nimbus feet: more substance in the lower miss, upper bass region, but colored.
Original spikes plus Harmonix spike platform: more easy to connect to the music, still more neutral than Nimbus
CMS MAXXUM
engaging, nice "emotional" sound, tonal more warm, that HRS in general,
but does not give the feeling of colored sound. Bass structure and contour nice, but less defined than HRS
High Resolution, structure and contour very good. In terms of neutral and most information the best, but dry and lean on the other hand. I added a heavy Multiplex wood plate (had no Panzerholz available). The tonal balance was more nice, but added a woody element to the sound.
I assume, that Herzan is similar to Accurion, so may be my experience will help a little.
In my personal set up that time with MAXX 3 I have chosen the CMS MAXXUM, as I enjoyed the music most.
status today is, that even my Heisenberg Amps are both placed on the MAXXUM, and the Accurion got the Artesania heavy acoustic glass platform on top and is used as Basis for my TechDAS AF 3 premium.
The HRS is waiting for the next job. I have two of them, so perfect for heavy and huge mono Amplifier,
we will see, what the future will bring.
on the ground
Rack and Platform
Findings:
HRS M3X
CMS MAXXUM
This is extremely interesting and relevant. Thank you very much for taking the time to write and post this!
Can I clarify something? So these impressions are with:
VTL on HRS platform (no low amp stand) directly on floor
VTL on Accurion on low CMS amp stand on floor
VTL on CMS shelf on CMS tall stand
I completely appreciate you giving us these impressions, but just to be clear, it seems like these are three different configurations (one directly flat on floor, one on amp stand on floor, one on tall stand) which make apples to apples conclusions difficult?
i suppose it is obvious.....it should be obvious; but comparing the Tana active 'system' to a 'nude' Herzan or Accurion is of limited value.
you'd have to go back and read the posts from Eurodriver (Ed Hsu) where he speaks to the higher frequency attenuation aspects of the Tana additions and judge for yourself whether that equates to 'alike' the 'nude' Herzan or not. i would agree it goes down the same road. below 200hz they two are alike in resonance attenuation. but the Tana is still better in those frequencies with the better power supply.But considering the Herzan is the active part, and the Taiko modifications are the passive part, a stock Herzan and a Taiko Tana must yield vibration results which are more alike than different, no?
it would be more correct to say that the 'nude' Herzan covers an important positive part of the Tana performance envelope, but then also consider that the Tana also eliminates the negative (SMPS) part of the Herzan.
also we know that both the Herzan and Tana need to be used where it both sits on a solid foundation, and the gear on top has no self noise that can be sensed by the Herzan or Tana.
Thanks for sharing these impressions, Shakti. Very interesting results.
Ron, My goal would be to retrieve as much information as possible while corrupting or changing it as little as possible. Easier said than done. It helps to experiment with many alternatives. Different is not always better, and IMO, one should have a clear idea of what he is trying to improve before he begins to audition alternatives and decides to get something new.
For this reason, I would hold off on any decisions, just as you are with more fancy cables. You do not know what your system will sound like when it is eventually set up. Why guess now and spend money now? Set it up, listen, and learn what you want to change first. You will have hardwood flooring over concrete slab. Will there be some interface between them? How are you so sure that the amps will be swimming in a sea of vibration and sound bad? Tang has his SETs on his LF horns. IMO, there are too many unknowns right now.
The CMS Portfolio is modular, so you can buy an Ampstand from the Maxxum, the QXK or the PXK range.Thank you very much, Shakti!
My only technical quibble is that I believe the Accurion/Herzan type platform is recommended to be placed only either directly on the floor or on a very solid and rigid stand or base?
Is the "standard CMS amp stand" a CMS product which uses a CMS "filter" platform (as with current CMS amp stands, I believe, which sits inside the stand structure), or is it a solid structure with no filter or base?
If it is the de-coupled filter style I am wondering if the lack of rigid coupling to the floor might have in some way confused or adulterated the operation of the Accurion (versus the Accurion being simply flat on the floor)?
