I liked the gray too it’s all beautiful! I’m just happy to see things moving ahead for you and Tinka.Thank you, David! I know you like the natural walnut, but I am still planning to stain it gray.
david
And you're stuck with him? Usually businesses that do a LOT of work can get permits done within the week if not day.
How's the rest of the house compared to the listening room?
The Mapleknoll is a great performer!
Yes, if you ordered your Eclipse with 2 inputs. If this is the case, you will have the option to alter each phono input load independently albeit inside on the back chassis.
Well, you have take a leap of faith with ordering and not hearing first.. don't judge the unit until after at least 400 hrs. Its break in is a long one. It will sound thin at first and go through different strange phases.
Your best bet is to get reverse RIAA unit-- they are inexpensive--- and run a CD player , tuner or server through it for 3 weeks or so. KAB, Hagerman and others sell them or if you are handy you can build one simply enough. Aesthetix say they put about 100hrs on the units before they leave.
Sure the stock tubes are fine, but NOS takes it to a different level. When you are ready for that let me know and I can give you some tips.
SMALLER PICTURES PLEASE. Those are massive.
Ron, how will the floor be finished? And is there any thought to the ceiling with diffusers, panels, etc? Can you get the contractor to pull permits? This project seems completely open ended. You are a very patient gentleman.
Before stain
View attachment 48744Finally had my flooring installed. Photos are kinda washed out but the wood floor has a gray finish. I love it! Hopefully the contrast with the amps will help.
Still need a few components.
Are you guys barking @ me?I gave up after five minutes and went to another thread.
So the flooring is installed wihout any sealer. It is engineered wood wih solid oak veneer. The stain was applied by the same guy that did the installation. Approximately 6 feet from front wall to carpet transition.
