Congratulations, Christian. That certainly looks solid. Did you consider having Herzan build a slightly larger top plate sized to accommodate the TechDas? I wonder how the sound would change without the HRS platform.
Also, now that it's been a while since you got your two phono sections back, do you find yourself listening to one more than the other?
I like the stand Christian.Price wise I suppose Herzan don't have the "Audiophile Markup". Did they leave the tube hollow or filled with sand etc??
Cheers Stump
I have just stumbled on this thread after hearing an accurion on a lampizator dac in action. I was impressed by the improvement on the lampi having auditioned it prior without the platform. I would like to know if this may be better than a symposium ultra platform which I now use. Would a component resting on a symposium which rest on a herzan or accurion be better than having the equipment on just the active platform? Is it preferred to have the platform on 24/7 or switch it on when needed better for its lifespan? Appreciate thoughts and views or sharing of experience.
It seems that most people use active vibration control under sources. Anybody try use them under power amp?
I have three Vibraplanes all hooked up to one compressor in my living room. It is not noisy and only runs for about twenty seconds once a day. I haven't heard it while playing music at the same time for months, so this is an unfair criticism, imo. I do have a good $500 compressor recommended by Sounds of Silence, the Vibraplane distributor..
Thanks for your contributions to this fascinating and long thread. I'm very interested in a Vibraplane-type solution for my system, but I'm curious about where you and other active vibration control enthusiasts place the *compressor*. Where and how do you arrange placement. My system is on ground floor with no convenient storage area nearby or underfoot. Would appreciate your insights on this. Jim (goheelz)
My Vibraplanes do have automatic level control, but they are not considered to be "active" isolation devices. They are passive, pneumatic, platforms. All three of my units are connected to the compressor and are set for 80lbs pressure. Two of the units have self or automatic leveling, meaning that when a footer looses some air, the sensor picks that up and it is automatically refilled. Once set with a level, it always stays level. My third unit, does not have this feature. I have to fill it manually by pushing in a switch which corresponds to a particular footer. This is not a big deal, but it does take time and is not as convenient, but it is very easy to do. I could also fill it with a bicycle pump if need be.
As for the compressor, I used to have it in the basement connected by 20' long very thin black plastic tubing to each Vibraplane. I plan to put it back in the basement. I was doing some diagnostics and it was more convenient to have it near the units. It is surprisingly small. You can contact Sounds of Silence, the Vibraplane distributor for advice.
For placement, you could find a closet or slip it behind a piece of furniture somewhere. All you need is a 1/8th hole through the floor or wall to run the tubing. It is sold in 50' rolls. You might also be able to have an electrician snake it along a wire or cable through the walls or conduit and out an outlet. That would be neat and clean.
for the sake of clarity, I will point out that an 'active' system essentially means that the isolating device can stop and start based on input from sensors. it 'offsets and neutralizes' the sensed resonance. passive systems are essentially springs, they offset loads and settle and overshoot. this is a massive over-simplification since passive devices have such a wide range of execution.
Sorry about my faulty nomenclature and misunderstanding about your Vibraplane system. I was mistaken to presume that having a compressor hooked up to the platforms constituted an "active" system. Your advice about remote location of the compressor may be quite helpful in my situation.
Currently, I'm using a Gingko isolation platform under my turntable. It's inexpensive and definitely a true "passive" device using squash balls as rollers under the top platform to help it float, as you may know. I noticed improvement immediately when I installed this item several years ago, particularly at higher volumes. You mention the option of using a hand pump to adjust one of the Vibraplanes. I wonder why that might not serve just as well as a compressor that runs only rarely to keep your preferred 80 psi in the Vibraplanes. My road bike tires take higher pressure and don't need to be filled all that often. I also wonder whether the Gingko (let's call it Stage 1 vibration control) is far less effective than the passive Vibraplanes you're running (Stage 2 seems the right term here). As you note, the Herzan or other true-active solutions (Stage 3 vibration control) are intriguing at a higher costs. One wonders about how much improvement will be seen. One also wonders whether some Stage 3 devices work without requiring an air compressor.
Thanks again for your good insights. Love the great system description you've posted, by the way. Clearly, it's also time for me to have a talk with the Vibraplane distributor to get additional specs and info.
. . . but you do need to always try to eliminate any compliance or passive device from below the active device as it will compromise the performance and possibly damage the active device......as the 'soft' passive device could possibly cause the active device to continually try to compensate and burn itself out. active needs a stiff solid base.
