Or maybe something you can discuss in a relevant, respectful manner, within the context of this thread, absent your bias and sarcasm.
Chill out dude and mind your own business!
david
It's not just with the Rossini there are a couple of other ones I've heard that do strings very well now, unfortunately also high priced. IMO This is were DACs have gained real ground in the last couple of generations. Of course you have to consider the transport as the half of the equation when considering RBCD.
david
You can clearly see the superiority of digital. Its graphs are in color and the LP in black and white!
As I said, case closed.![]()
Personally, I keep getting caught up on the idea that
1) digital is "closer" to the mic feed; but
2) analogue gives a sound subjectively "closer" to "reality".
(The "" are there for obvious reasons.)
But for someone who believes in objective 2) "reproduce exactly what is on the master tape" a clean test tone from a format is very important because it is viewed as being highly probative that that format will reproduce accurately what is on the master tape.
Correct me if I am wrong but since around 30 years all vinyls are made from master studio files , not master tapes.
There is a special technique called Direct Cut developed by Stockfish Recording, but still their vinyls are made from DSD files if I am not mistaken.
How possibly then the vinyl made from digital source may sound better than master studio digital ?
I agree that analog subjectively is more close to our perception of live music but it has IMO more to do with the way we perceive and process the sound in our brains, not with the format itself.
I can top that one. There is a subset of audiophiles who maintain the wax cylinder would do a few things better (At least they didn't say) than today's analog... Too bad I can't find the link.
Al M., if a test tone can't be reproduced correctly, then there is no hope of a recording being "accurate". However, as you point out (obviously), that is not a sufficient criterion for accurate reproduction, it is just one of many (most probably not quantifiable).
personally, I have found Menuhin's string tone quite a tough one to "tame", it often conveys the impression that he is just sawing away on a tool piece, rather than "making music" ...
Yes, being "subjectively close to our perception of live music" to my mind, should be the starting point of any analysis as this is the reason we listen to audio - to fall for the illusion, to be transported.
With such an analysis t may turn out that the "believability of the illusion" is simply because of the processes required in the production - as F1 pointed out.
Or it may be that there are other yet undiscovered strengths that vinyl implementations have when compared to digital audio implementations
As AL says, to him, there are only a couple of convincing examples of baritone or tenor sax - why? What is it that dCS are doing which gets it right? It doesn't seem to be the format but rather the implementation of it that needs more attention
david
But I don't believe this is correct. I believe that we all have pretty much the same internal model (which is a very complex set of aspects & relationships that defines how auditory objects sound & behave in the external world - I'm trying to simplify it). It's very like the model of how we learn correct grammar - we aren't taught it, we learn as toddlers by constantly hearing how others (adults - the practised ones) speak & we imitate, eventually subconsciously incorporating a a model that allows us to construct grammatically correct sentences - I suspect that this is done more by what sounds right than by adhering to "rules of grammar". This model is more or less the same for everyone, we are all exposed to the same examples (speech) everyday, although there are outliers.Yes , I could agree with that but IMO we ignore in this approach that we also perceive the sound differently.
OK, you are really talking about training & becoming accustomed to a particular set of tonalities &/or artifacts. Yes, we can be unaware of what a particular distortion sounds like but still be able to prefer the device with the lesser distortion - it just doesn't sound "right". If we look at the Harman graph of speaker preference - the "trained listeners" group still scored the speakers in the same relative order but marked them all lower on the preference scale compared to other groupsAnd we all the time develop our skill to listen to audio signal in the process of learning and processing through our former experience.
This is why someone who listen 90 % of time to vinyl does not like digital and vice versa.
Only those who have enough expertise with different formats and sources may have a bit less " source driven" opinion.
What I want to say is that when you spend say 100 hours only to evaluate different native DSD recordigns of tenor and baryton sax you are able to make any judgemnet wheter analog is sitll - or not- better.
One time experience is not enough to change the perspective, again IMO.
I suspect wax cylinders would not suffer from inner groove distortions
Yes, i never claimed that vinyl is capable of technically accurate reproduction of master tape. It just isn't. Case closed, as Amir would say.
Yet nonetheless, for some reason, vinyl retains the complexity of the harmonic spectrum of certain instrumental timbres much better than most digital.
Dear David,
Which other DACs or one-box RBCD players are the couple of other good ones to which you refer?
