Thats what I use.. 5kw pure sine wave convertor , fed by 6 x 200ah deep cycle batts.. solar charged
Cant say that it gave me any better sound tho .. we have power problems in SA .. surges , brownouts , sags , rolling blackouts...hence me using it
My mistake. I highly suggest some kind of control for noise for anyone using an inverter. The "straight to the wall" purity doesn't work.
Hi Ron
I've been to your house and seen the structural problems and as you said spending $200K for nor reason is silly. Besides wouldn't it start to encroach upon your pool deck
Yes, the extension would have encroached upon the pool deck by five feet.
Ron, that $200K estimate could end up being $225-250K when all is said and done. Estimates/quotes are often low, especially if unforeseen issues arise. It seems that you are making the right decision to not go forward. I like Folsom's suggestion that there may be an alternative option in another location, though that all depends on how you listen, public vs. private dedicated listening room. These things are not so easy.
That's way too much. I take it they'd have to structurally redesign part of the house and tear apart a lot more than that room? For a fraction of that price you could build a new different room that's better, as an attachment, if your property allowed and you wanted it in such location. I however understand not wanting that, and appreciating specific room and access.
How big is the room going to end up being?
