20140306_152213 by
andromeda61, on Flickr
The 13 inch woofer and 11 inch woofer will be sidemounted in mirror image , facing inwards , the 11 inch is placed above earlevel to give a more roomfilling sound/bass .
The tweeter and mids are frontmounted in MTM configuration , no dampeningmaterial is used in the frontbaffle instead the front slopes gently (absorbing material improves focus but lowers system efficiency it also makes the sound a bit duller/less dynamic imo )
They ll be supplied with either own design footers or otherwise finite element classic for example which are also nice and well made.
The woofers are sidemounted to reduce baffle width and because I want to try it out soundwise .
Papercomposite mids and softdome (ringradiator ) highs ,woofers are from eton , because they are very stiff but natural sounding and are high efficiency plus they have a very low resonance frequency .
No more thiel units , because I found some now that are a lot more natural sounding, never ultra hard /brittle membranes again for me ,that's why I didn't bother with berylium tweeters( scanspeak) for example , they are cheaper as well but price wasn't a concern , this was a case of cheaper and better imo ,sometimes you have to forget the specs/price and just listen
They have to have a certain basequality off course, whether the berylium ones have the slightest edge in resolution or not (which is far from proven as far as I am concerned) , there is more to it then the last bit of resolution
The speaker will be around 1 meter and 35 centimeters high (incl footers ) around 94 db efficiency and has a custom designed
high impedance X over
The design philosophy behind it is a loudspeaker that is transparent/ coherent / natural/accurate sounding with very natural (sometimes explosive )dynamics and very low coloration , simply a speaker to enjoy and forget about ,because you just know it sounds right .
Its not designed to be a constant changing audiofile fiddling tool, this speaker will play optimal (99 % sure ) with either a 8 watt set or a 1000 watt solid state , with such a speaker you only will test amp quality /characteristics .
