DSC_0117 by andromeda61, on Flickr
DSC_0118 by andromeda61, on Flickr
DSC_0120 by andromeda61, on Flickr
DSC_0121 by andromeda61, on Flickr
DSC_0122 by andromeda61, on Flickr
DSC_0123 by andromeda61, on Flickr
DSC_0124 by andromeda61, on Flickr
DSC_0128 by andromeda61, on Flickr
DSC_0127 by andromeda61, on Flickr
DSC_0126 by andromeda61, on Flickr
DSC_0125 by andromeda61, on FlickrWell its time for a zanden review , the review is based on the zanden alone not with the cat driving it, it is used with the sophia electric royal princess tube 1000 euro pair considered one off the best , the takatsuki possibly bettering it at 1800 euro retail :
I was a bit afraid how well it would drive the speakers , but the zanden SET 300 B came along for a reasonable price from a person who lived in amsterdam , so i thought i give it a try .
Plus :
most obvious is more transparency and detail , it is said SET s are detailchamps and that is very true compared to the cat /krell/hawk amp .
Bass , believe it or not bass has improved , it has more weight /aplomb it is fuller and more defined , it fills the room with low freq more so than the krell, especially with organ or orchestra music , most movies as well , although gunshots(heat ) sound a bit more fierce/snappy with krell.
Voices and music on cd and musicaldetailsoveral are on another level , the feeling of reality has much improved
sense of space has improved and the soundstage became bigger
I think its been a logical upgrade and a good learningexperience .
I probably would state from now on that tubebass is better than SS
Headroom is enough but that is all , i usually listen to cd s at vol 12 or 1 oclock and movies at 3 oclock so i have some headroom left although its not that much but no problem there .
There is absolutely no sign of compression when driven with volume fully open , no smearing or harshness just pure clear sound
The person whom i bought it from said he never heard the zanden better , he heard it on tannoy and audio note speakers
He himself listened usually with AKG K1000 headphones
neg :
I am afraid i will have to buy the zanden 1200 phono as well in the future , the cat phono is now to noisy at listening volume and i think the zanden will deliver much more detail and transparency and overal sound quality .
I do know the legend is much more quit and has a step up transformer built inside for up to 58 db gain
The zanden 1200 has 2 gain outputs 1(high) is 68 db (probably more dynamic sounding then compared to the legend )
I do suspect a problem though , using my beloved decca carts on the zanden as it has a fixed loading of 4 ohm on the high gain output and a fixed 40 ohms loading on the low gain output , deccas need the 47 kohm loading to sound good and going lower reduces the soundlevel and doesnt sound nice , on the cat that is
The krells do sound a bit better with electronic music / house
Thanks.I found it not so hard to set up it tracked good at the recommended tracking weight , it sounds lively and has a " tape like " sounding quality about it at least thats what i thought , it does need a check up /readjustment after about a year .
i am more into analogue tape now ,playing LP s takes a lot of adjustment /care to sound right
Lloyd this is it , designed to compete with anything on the market regardless of price but roughly the same systemsize (membrane surface ).
i lll make a full wooferreport in a couple of weeks
I will do that in the not so distant future , it sounds awesome already , its a whole new sound expirience , most obvious is the uncanny decay of notes , hearing the snap/ decay of for example a xylofoon being hit is unbelievable almost , image stabilty is perfect now as well
Woofer integration is already very good from the start after little x over tuning , it goes clean and deep it carries the soundexpirience to a complete level , i think i made a very good choice to go with sidefiring woofers first there is a practical advantage secondly it appears the soundstage and low freqs are more disconnected from the housing this way , there is a massive soundstage build up between and behind the speakers
Furthermore this scanspeak illuminator soft dome tweeter is the highest resolving tweeter i have ever used in a model , the housing has added to the qualities but still
