Just some questions. Does the Clearaudio table have any suspension of its own, or is it technically an unsuspended table? Do you have the turntable stand on concrete slab, or was it on a wooden floor on a second story?
I was shocked at the improvement the Herzon base made to Christian's system. It played with so much more poise during tough passages, where before it got a bit edgy. More resolution too and a richer presentation. Took his system to the next level for sure.
my Herzan TS-140 active isolation shelf arrived yesterday, and I installed it last evening.
I had been looking forward to this since 2005 when a reviewer from Positive Feedback brought over a Halcyonics for me to try. 3 years ago I switched from Grand Prix Audio Monaco decoupling shelves to the Adona 'grounded' racks to be able to optimize isolation devices such as the Herzan. when you combine isolation systems both systems are compromised. back in 2005 we had placed the Halcyonics on top of my GPA Monaco decoupling rack, yet it still sounded wonderful. how might it do when given the chance to work as designed?
no doubt I had big expectations. however; I also thought there was a chance that there might be take-aways that might compromise the benefits. with isolation devices my experience had been there are no absolutes. I did not know anyone who had tried one of these on a SOTA turntable. might it soften the sound?
it turns out it far exceeded my expectations. and I think besides the grounded, mass loaded Adona rack it sits on......and the 6" of concrete the Adona is spiked to, the NVS tt is an ideal match for the Herzan since it's designed to work with it's own isolation shelf. and Wave Kinetics started out as an isolation device builder.
i'll start out with the areas of my concerns, which I need not have had. the snap, impact, and weight of transients and bass is on a level I've never heard before. a huge improvement. and those things were already amazing. now they are 'real'. detail and focus is improved for everything, there is more density, texture, and harmonic sparkle......a vivid 'live-ness' that is hard to describe. the separation of every individual aspect of the presentation is another large improvement.
but really, the important thing is that music is more involving and compelling, there is a greater sense of the playing together, and the emotional content is much greater. I cannot stop listening.
I am astonished at what i'm hearing.
View attachment 10161View attachment 10162
Iit turns out it far exceeded my expectations. and I think besides the grounded, mass loaded Adona rack it sits on......and the 6" of concrete the Adona is spiked to, the NVS tt is an ideal match for the Herzan since it's designed to work with it's own isolation shelf. and Wave Kinetics started out as an isolation device builder.
Congrats Mike and Rockitman, I certainly have audio envy at the moment. My TW Raven AC-3 would probably benefit greatly.
Is the Herzan really plug and play with a turntable? Does the Herzan auto level if the table is not quite loaded equally? I know this can be av problem with Minus K for example.
How much does the Herzan move?
Cheers
That's a very nice looking turntable Mike. ...Awesome that your music is now even more involving with your new found 'foundation'!![]()
Congrats Mike. You summed up my impressions exactly. My replacement unit arrived today. I even installed a brand new cart and it still sounds amazing. (Koetsu Tiger Eye). Have you checked out the lcd screens ?... in particular the axis display ? With active off, you can snap you fingers and the TS-140 detects it by excited lines on the axis display. Re-engage active and the lines don't move. The balance/weight screen is also useful to optimize the balance of the TT on the TS.
Congrats, Mike. I have heard a system that has the Halcyonics tables under a Scarlatti stack, and indeed when you even brush the unit the meter lights up and you know it is actively counteracting the movement. Quite cool.
the Herzan and Halcyonics are the same basic technology and work the same. both have products which don't have automatic leveling for $2k-$3k less money. if I was using one of these under a non rotating piece of gear I might not need the leveling and go that way. but under a tt or digital transport I would definitely get the leveling.
the Herzan has the advantage of being a shorter form factor which to me was very important, and the Herzan has slightly better specs in terms of how low in Herz it operates (attenuates noise).
compared to most tweaks, these products are based in solid science, and are fully vetted to deliver specific performance. the medical and science research facilities which are the target market would accept no less. these products actually do what they are supposed to do.
Mike why did you choose the Herzan over the Halsyonics?
thanks.
the Herzan will be ideal for any non-suspended tt, particularly on a solid (non-decoupling) grounded rack on a concrete floor. if the turntable has an integrated suspension that cannot be defeated, or your rack is decoupling in some way, or your floor is springy.......any of those factors will compromise the performance since the Herzan will sense those actions and have to try to defeat them. it will still be excellent, but not ideal.
at the end of your session hit the 'isolation' button to turn that off and then turn off the power switch. the reverse to turn it on.
