What issues with wood floors? Vibration? Scratches? Isolation? Isolation can be obtained but costs -- you have to build a room within a room. There are special dampeners used to support a floating floor (then you have to float the walls and ceiling, too).
Still wondering if I should have mapped out a way to support the ceiling on the (floating) walls, but ran into code problems that would have cost me another foot of height and I didn;t really have it to give...
How about 25mm gauge carpet over concrete, would that work?
What issues in particular caesar?
Just looking for good sound. I'm thinking of a concrete with a hard wood floor on top of it.
Mike L has both. His room is above grade and the front part of the room is hardwood and the back half is carpeted.
