Anything under 1m baffle width (side wings then you get 30hz with full soundpressure) doesn't produce deep bass unless you fill it up with DSP and a lot of amplifier power.This mainly depends on the (size of the) room. You could also replace the upper + lower 10" with 12" woofers, or use 4 x 12".
10" woofers are quite common.
The 'clean rolloff above 3kHz' isn't the main issue, beaming/cancellation/lobing are.
Every decent sounding OB/Dipole system with 15" woofers I know features a low(er) LP for the woofers (<800 Hz).
