The Problem of reproducing large scale Orchestral music
This mainly depends on the (size of the) room. You could also replace the upper + lower 10" with 12" woofers, or use 4 x 12".
10" woofers are quite common.
The 'clean rolloff above 3kHz' isn't the main issue, beaming/cancellation/lobing are.
Every decent sounding OB/Dipole system with 15" woofers I know features a low(er) LP for the woofers (<800 Hz).
Anything under 1m baffle width (side wings then you get 30hz with full soundpressure) doesn't produce deep bass unless you fill it up with DSP and a lot of amplifier power.
Agree, in my speakers the 15 inch woofer cross at 1.2kHz to the CD, but it is a 1 inch (exit) one.
There aren't much 1 inch CDs which allow to cross below that if you like to play loud :cool:
I would not really go much below that with a 1 inch compression driver either. The one I use (Beyma CP350Ti) I cross at 1.8Khz. The 1.4 inch throat driver I use (Beyma CP750Ti) will go down no problem to 800Hz (it is a 3 inch diaphragm). Both will play ear bleed levels with 1 watt.
Glad it works for you, not for me, I like high energetic sound from 12 and 15" drivers e.g tone tubbys, acoustic elagence..beyma.
Listen this that will change your opion 102db/1watt active ripol 18" below 70hz
I have heard Bastanis...it doesn't change my opinion. I like them but not as much as my Honrnings, which are similar in that they have a crossoverless midrange, but they use a small 5 inch high sensitivity driver (Lowther huge 10kg magnet and whizzer removed) that has much better off-axis dispersion. I also much prefer Odeon Semper.
If you're looking for something comparable in the world of horns, there's no way around the sato horn. It works from 150hz - 5khz with the right drivers. The two 12" bastanis work from 70hz-5khz. The sato horn has a little more headroom thanks to its high sensitivity. What's important to me is that one driver seamlessly covers a large frequency range. Both systems produce an excellent, dynamic, thrilling sound. I don't know your hornings, the main thing is that you're happy
look them up...easy to do. The main driver covers <200Hz to 12Khz.
I am curious which 1 inch compression driver Odeon use in the Semper. Do you have any info?
Thanks
I don't know the brand. All I know is it is 38mm mylar ring radiator with Nd magnets...maybe BMS? If so, the BMS 4540 seems the likely candidate...
Clearly, they prefer the sound characteristics from the dome/horn over bringing the woofers up higher, which is also what I found out from my
This is an interesting topic; it's not a black-and-white issue, but rather a process of choosing between compromises (as with everything in audio).
Take, for example, the SCAN SPEAK - VIFA M21WG-09-08. This classic 8" woofer was an obvious choice for simple two-way speakers in the 80s and 90s and is still used in the Audio Note AN-K paired with their version of the famous D19 3/4" tweeter, with a crossover around 3 kHz.
It works, very well I'd say, but within certain limitations. Naturally, this speaker is not suitable for sustained high output levels; it's not the most resolving in the midrange, and its LF extension is limited to around 50 Hz.
Similar phenomena apply to the systems highlighted by DasguteOhr.
It depends, not only on baffle-width but also on driver Qts a.o.
But yes, in order to get output below 40 Hz you'll need more Sd.
I don't like DSP and high power amplification (anymore), except for PA.
