Physics is actually a science.
Magic is not a science.
We might be able twist Alchemy into being the grandfather of modern nuclear physics, however in terms of electronics Maxwell sort of removed a lot of mystery from the ‘equation’.
Oh , really?! I did not know that magic was not a science, as my Auntie witch Hazel gave her flying broom designs and appropriate spells to Wright brothers for a mere two pounds of pure Beladonna powder from Oregon....
Having been raised in family of 2 and half physicists, and having tried to copy some ancient Alchemy experiments (which led to an explosion in my friend's garage on Long Island) as I was sorta good at deciphering some ancient Jewish Kabbalistic cryptic texts on the subject (not that fake Gnostic crap) , I can tell you that those two fields have very little in common... Apothecary and chemistry may be ;)
Reactions: Holmz
^Well done sir!^
I think Brookhaven is on Long Island…
Those old alchemy attempts at making gold from lead, sort of is actually on the right track of how things work in the nucleus of an atom, in which they absorb huge numbers of neutrons in cosmic events.
That just happens in milliseconds in the cosmos, whereas the old alchemists did not have Erlenmeyer flasks of spare neutrons to pour into the base material, like is available in neutron star mergers.
I don’t know any Aramaic, etc. which would be needed to read the other texts ;)
The tubes used in transatlantic applications did not go off and on ,and lastly were not in a room producing large amounts of acoustic energy. Lastly music unlike a phone has a constant change . If you used a stethoscope you can hear your music pretty good
Same on SS transistors .
I washed a video with chand of his very nice home and many audio rooms . In one part he has a set of quad panels on an el34 amp
He was told he never needed to change the tubes ever . There is some truth to this , but this leaves out the slow death of sound quality being heard.
With tubes being turned off and on as anyone does a few things happen no matter what it's designer used to hold off things
one is inrush current on not just the heater . But the plates too
a chemical blackening happens and this can be measured in tube conductance
Tube have magic in many ways , as do various non tube devices.
I think the glow of tubes adds to a almost endorphin release to some .
Myself included.
The 2A3 is one of my favorite tubes as well as el34 types
Both to my brain show speed but speed is a made up term but seems real to me .
With my amps, you have to turn on the heaters and let them run for a minute plus. Best to wait till all the hazey fog is off the glass. Then you flip the high voltage on.
I think a lot of tube life also comes down to how hard do you run them...My Mercury rectifier gets run hot. As such, I seem to fry them about every 1000 hours. Good thing they are like $40 each. The drivers and voltage rectifiers can go thousands and thousands. Maybe 8000 to 10,000. Not sure about the kT88. They have run over 1000 and still sound great. I am told the should go 3000 to 5000 hours. Part of why I bought the amps. New power tubes are $500 for a quad which fills both amps. Thats good tubes like Shuguang Hidden Treasure 50th Anniversary. Or KT120 from Upscale. The KT88 is better.
In my preamp, the voltage tubes have been running for 6 years. The signal tubes maybe 2. I swap them out depending on the flavor of sound I want. But they should both go tor 10,000 hours plus.
Please cease on my system thread the irrelevant discussion of fuses.
  • Love
Reactions: XV-1 and Johan K
Congratulations, Ron!
I’ve spent time with the Incito S, Ageto, and Aether Pre-Amps, and also listened extensively to the Impera. The Incito S is truly something special, especially at this price point.
I’m eagerly awaiting my own Incito S and Aether Pre-Amp (Legend Series)!
Reactions: Lagonda and Johan K
Ok, then give us an update on the installation and initial sound quality results of the Incito S. You have your masses to entertain! ;)
Hi Brad,
Sure! The update is that there is no update. I haven't moved the unit from the crate in its original location in the garage.
Reactions: Johan K
