actual audition in my system:
VTL TL-7.5 Series III
Trafomatic Lara
Hovland HP-100
Hegel P30A
Soulution 727
extensive hearsay research and triangulation discussions with people who have directly compared in their own systems Incito S to preamps on the list above and the list below:
conrad-johnson Art88
Aries Cerat Impera
Alieno preamp
Zanden Chukho
What did you find qualitatively different between Incito S and something like the very expensive Soulution?
A question for the ages, in our hobby....
By the way is it known how many hours do tubes last in the Incito models? I believe high quality NOS ones are being used, so wonder if the unit can be left on continuously for a while (like 40-50 000 hours with some proper Telefunken, or Mullard NOS) ? Thanks !
The E280F will last at least 10k hours I think and the GZ34 lasts a long time as well. I rolled my rectifier a year or so ago to improve sound but the original one was working fine still. I have the same output tubes in it since 2017 and there is no noise and no degradation in sound quality (I did briefly roll some others in to check…but just a few days).
Reactions: AudioLibertarian
I had the Soulution only very briefly -- like two hours. This unit was brand spanking new right out of the box. Still, from those two hours my friend and I thought it sounded excellent. I really can't be any more specific than that. Just from this very brief visit I do feel like if somebody is considering a flagship solid-state preamp they should hear the Soulution.
At normal volume something triggered its protection circuitry and we didn't use it after that.
Not sure why you listed it in the audition list if you did not audition it properly. The solution preamp is fantastic when combined with valve power amps
Yes, IME a solid state preamplfier will need a much longer warm-up period.
Well, this can be due to ultrasonic high frequency oscillations in the source equipment. In such conditions, probably preamplfiers using coupling transformers that filter them and would sound better.
RF oscillation/resonance in power amps is real and frightful thing.
I always get a bot confused as to whether it is capacitance or inductance that moves the ‘pole’ outside of the circle… but I think it is capacitance.
If the ICs are long, and more than one IC/channel, then it may be moving things in that direction.
That stuff kind of needs a real EE or skilled tech type.
FWIW Dept.: the output impedance is often measured at 1KHz. Its useful though to know its output impedance at 20Hz too, especially if the preamp is driving more than one amplifier. If the preamp uses output coupling caps or an output transformer the 20Hz output impedance is likely higher at 20Hz. With coupling caps its often a multiple of the 1KHz value.
That formula I gave you for calculating the capacitor value a little while back is very useful for this situation too if you have output coupling caps (which most tube preamps do; ours is a bit of an exception as it has a direct coupled output). Let's assume that the amps all have a 100KOhm input impedance; the three of them in parallel is 33.3KOhms. You might want to plug in whatever value your amps actually have into that formula and see what the cutoff frequency is. If it is above 2Hz there will be phase shift in the audio band- up to 10x the cutoff frequency.
The 50Ohm output impedance means the preamp will not distort when driving a 5KOhm load (using the 10x rule that the source impedance be 1/10th that of the load its driving to prevent distortion). But the cutoff frequency is a variable too since that describes bass impact. Since you are using multiple amps its worth doing this math!
I truly wonder who understood the tech of your great post , not joking
My guess is some people will listen and if it don’t sound good trash the product not considering the application used
Two questions
One is my Krell amps need a min of 2 hours to settle in how they sound
the idle temp is reached in less then 30 mins in the summer. The amps have there own room I can’t deal with the heat they produce
while they have new caps all done by myself they were like this always
next is I’ve noticed on some pre amps even phono pre amps gain can have an effect on tone. Matching gain helps make things sound better that’s the easy part
but tone ???
my cables are short and low capacitance
Too why does this happen
I can see why Ron picked the gain
Very good comments on the output impedance - it is why it is why I always look at the value of the output coupling capacitors. If they are not clearly seen I measure them!
Some tube preamplifiers having less than 500 ohm output impedance will not "distort" with a 5 kohm load, but will show higher distortion with such load than with 50 or 100 kOhm. In my experience most of those I used sounded better with loads higher than 50 kOhm. Unfortunately most preamplifier reviews only show us distortion loaded with 600 Ohm and 100 kOhm.
Never heard about audio tubes lasting 40-50 000 hours, except for the famous Western Electric 300B that is known for lasting 40,000+ hours in ideal conditions. Expect something up to 10 000 hours for some NOS tubes, such as some Telefunken's. Unless we know the exact operation conditions of a tube, it is hard to have a good estimate of tube life.
Reactions: Argonaut
Yup … Raised any eyebrow , Roger Moore style , at that one also !
makers should show a few output related specs
Voltage se and bal
Imp output at a min of 5 freq at given loads
the size of the cap I think
ralph can better explain what specs by documented testing should be
Tubes decay and documentation is available for testing specs to know
depending on its usage the aging process changes.
Rectifiers cook if on and connected to a psu circuit load switch or not.
tube filament is I think first to decay and depending on ac or dc filament voltage has a big difference
from what I had read each time we turn a tube on decay happens leaving them on in certain circumstances maybe better
lower filament voltage can help or hurt
Putting aside sound. tubes are designed for a specific purpose. We in audio many times use tubes not designed for audio.
by specs military grade tubes might last longer but still have an obvious lifespan
Lastly a new in the box tube needs to break in I think we all agree to this.
but then at what point does the sound decay enough to warrant new tubes ??
for me on larger output tubes I feel take the given hours specs of a maker and cut in half
I’m sure this is also raising eyebrows now.
I use tubes in a few headphone amps
headphones are like a microscope into the music
take tubes you have used about half or even a bit more then half and use new or even better a pre broke in pair as I do
It’s a good method of keeping your tubes best
I’m not saying an old tube don’t play music but im
Pretty sure it’s not like new anymore
Reactions: StreamFidelity
I believe high quality NOS ones are being used [in the Aries Cerat Incito S preamplifier], so wonder if the unit can be left on continuously for a while [...]
[please forgive my poor English]
To sum up what I've read in various threads and on the Dutch HiFi-advice website's Comments section, in which Aries Cerat's designer Stavros Danos himself replied and brought clarification:
- the manual says: "it is advised to avoid frequent on-off switching of the unit to preserve tube life" (even if there are three chokes in the Incito (S), one for each tube).
- nevertheless, "2-3 on-off power cycles a day" is not considered as frequent [says Stavros].
- for instance, turning on the gear before a listening session and off after the last listening session, is fine. (During the weekends, this could go up to 12 hours on, but it is still much better than 24/7.)
You can find DETAILS and Stavros Danos' answer here (on that site, each reply has its own link, so you have to start with my question first; then scroll down to Stavros' reply then to the Dutch AC distributor's reply afterwards; his name is Ron too):
https://www.hifi-advice.com/blog/re...helene-dac-and-incito-s-preamp/#comment-16104 //from this link, weirdly you cannot scroll upwards to the review itself, so...
...link to the review itself:
Aries Cerat Heléne DAC and Incito S preamp review, Hi-Fi Advice (Christiaan Punter) // this link opens at the beginning of the review, and gives access to the Comments too (scroll down).
The tubes used in transatlantic applications did not go off and on ,and lastly were not in a room producing large amounts of acoustic energy. Lastly music unlike a phone has a constant change . If you used a stethoscope you can hear your music pretty good
Same on SS transistors .
I washed a video with chand of his very nice home and many audio rooms . In one part he has a set of quad panels on an el34 amp
He was told he never needed to change the tubes ever . There is some truth to this , but this leaves out the slow death of sound quality being heard.
With tubes being turned off and on as anyone does a few things happen no matter what it's designer used to hold off things
one is inrush current on not just the heater . But the plates too
a chemical blackening happens and this can be measured in tube conductance
Tube have magic in many ways , as do various non tube devices.
I think the glow of tubes adds to a almost endorphin release to some .
Myself included.
The 2A3 is one of my favorite tubes as well as el34 types
Both to my brain show speed but speed is a made up term but seems real to me .
Reactions: Atmasphere
Myself included.
+1
2a3/el34
Submarine tube for telephone cable
Whenever the signal fell below a certain strength, this tube was installed in the cable.
There is still an emergency connection between Europe and the USA today. Some tubes have reportedly been running for 60 years.
NOS 1950-60 Telefunken & Mullards & CBS Hytron with golden pins, , 12AT7, 12AU7 types, other input tubes, from my personal experience, used in the preamp and amp circuit.
