In this case I preferred the second video too. The differences apart from the cable is also the power treatment.
It has more nuanced contrasts, better suspense, decay, pauses. The first one relative to the second sounds a bit flat. I don't put this down to silver vs copper more of Kuro vs whatever Tang has in copper. Plus the power change and the back panels might have made the difference
It would be good if Tang can record with the WE SUT the same piece.
Also Mahler 3 the first movement has a very long first wave, you really shouldn't stop it at least until around just after the 15th minute. Soon after you stopped the bold opening where you show how your system handles the french horns and trumpet, there is a very sweet melody with oboe, flute, and violin, then the trombone that plays will really show if your system can handle it, i.e. not sound thin and tipped towards the high....then the whole orchestra picks up beautifully.
