And here is a difference between IsoAcoustics Gaia II and stainless steel spikes with sound demo.
IMHO, when done well much more musical than a parallel X over.This time a series X over
Nice! Which CD and CD player are you using?
that is my impression about the CAT amplifier based on a couple listening sessions. Not all tube amplifiers are like that.
Heard the same comparing NAT to CAT.friend in London had the JL7 for two weeks on Avalon compass diamonds, his Allnic 300b was better than it on all LPs he and I tried. He really wanted to like it as he wants a bit more juice but it just doesn’t have the musical nuances and emotions of the Allnic 300b so returned it.
Lamm is a hybrid. If you are going to consider hybrids then I recommend an Ypsilon Phaeton...might be able to find one just over 10K used. I would recommend the new AC triode/FET amps, but they go well beyond your stated budget.No its not gonna be another tube power amp for me .
I dont wanna spend a lot either , i like to stay under 10 K second hand
I was may be thinking of giving a KARAN 400 a shot , sounds good on YT , lol.
Karan and the LAMM 1.2 ref are one of the only few SS contenders i havent heard yet
Thanks, is this the album (Tidal version)?
Not sure even a Wadax could save this one.Yes the recording which says vivaldi CD ( its this one.)
Its just a CD.
The other music is streamed of YT.
Unfortunately no wadax here .
One submission and no cats meowing in the background.
Sounds great! What software/streamer/dac are you using?One submission and no cats meowing in the background.
