Grandinote Mach 8 XL vs Mach 9 speakers
There are still plenty of hidden gems to be had, fortunately!
FYI If carbon fiber body speakers are desired, the Perlisten has just come with their own such model S7 & LE, at 29K, with street prices likely in low 20s. I'm not big fan of that brand for few other reasons, but looks very interesting from speaker aficionado's point of view, I must admit, as they seem to have copied rather well many design cues from European and American companies. Apologies for mentioning those in the Grandinote thread, just in case :)
Why look so far? The Grandinote Mach 8 XL is itself one of those hidden gems even today.
Yes, its more compact cabinet may give up a bit of scale due to lower air pressure, but even so, compared with the newest 140k flagship on the most demanding material, it still performs far beyond its size in real-world musical engagement.
Match it with a pair of REL Carbon Special subs crossed over around 70 Hz and the Mach 8 XL becomes genuinely formidable. In that setup it can comfortably outperform many heavily marketed low-efficiency statement speakers, even on large-scale orchestral works, not in specs or hype but where it truly counts: musical involvement, coherence, and horn-like dynamics, all delivered with that effortless organic flow Grandinote is known for.
So while carbon-fiber cabinets are interesting, sometimes the real jewel is already right in front of us.
You should really put Grandinote speakers next to your Sashas in your own living space for a couple months and listen to them side by side before making statements like that.
Unfortunately, your wishful thinking is far from reality.
Personally, I think they are much better than modern Wilsons, Magicos, etc., in most genres. However, while I haven’t experienced them personally with large-scale orchestral works containing 50 instruments, if your assessment of their limitations in this genre is accurate and not related to room modes or break-in issues, this could easily be addressed with two REL subs crossed over around 70Hz, effectively covering any low-end shortcomings. That said, the fundamental weaknesses of low-efficiency designs with transient response issues, phase problems, thermal compression, and high-order crossovers cannot be corrected by anything. These designs, especially for classical music, will still suffer from incoherence and a lack of lifelike energy, particularly in terms of flow and dynamics, when compared to well-designed high-efficiency systems with simple crossovers and a properly matched structure.
Reactions: morricab
