Offset is the leading nulls and trailing nulls that enclose the music data in the total data record of any track at any sample-rate. It seems logical that this should not matter for sound quality, only the data words themselves.
Maybe not so logical....
So I have made four test files available here that all have identical music data fields, but different offsets, so you can see if you can hear any difference in your system. It is interesting to determine if there is any DAC or re-clocking sensitivity here, so please list your DAC and if you use a re-clocker or if the DAC has a re-clocker inside being used. Also please list the playback software you are using.
The files include two 16/44.1 files and two 24/96 files of the same track. It is a piano track. I will not tell you yet which tracks are untouched and which have more nulls inserted into them.
Download the four tracks here:
https://www.dropbox.com/sh/g9jz9lwgvozepic/AADx1d8YLCr5YCPQl23fUkFDa?dl=0
I would like anyone interested to listen to these tracks and report back on what they hear, describing things like dryness, ringyness, attack, decay, warmth, depth or shallowness of soundstage, clarity, wooliness etc. with each of the four tracks and rate them 1-4 with 1 being the most live sounding and 4 the least.
PS: I suspect that this might be one of the reasons that one playback software sounds different from another, or differences between one release and the next.
Thanks for your help,
Steve N.
Empirical Audio
Steve N.
Empirical Audio
