Mike … Would not your “never to be quieted” quest for the suggested ultimate vinyl transcription not lead you to visit the reportedly evolved “Sound Of Nothing” turntable … You once having previously moved rather close to securing its predecessor the AS 2000 ?
nope. i chose the motorhome + related commitments to more vinyl quest pain. and in any case not sure there is a next step, or if so whether that would be it.....for me.
there is myth and legend and process. that one belongs in that discussion. a few others too. including maybe my T1. might be a dozen to ponder. i can still do that. ponder....that is.
Well people listening to Qobuz will tell you they have 100 million compelling reasons to love digital, including 185,000 albums in Hi-Res audio
which i have and really enjoy too. so i know where that fits in compared to my vinyl. and my personal view is that it does not quite reach my 12,000 pressing level. i know that is not your view.
The main reason I will keep vinyl playback in my system - the other being nostalgia and some respect and love for rituals.
says the man seriously considering a further huge commitment to digital. hope you pull the trigger. i did.
Yup … Makes sense to me .
mine, yes.
like to? i will always 'like to'. yet.......
Peter, i'd say i am at my vinyl performance destination. when i listen to it i am consistently taken by it. the superb musical connection is fresh and new to me. i realize there are likely some mini steps out there to be had if i were still on the hunt. would i hear a difference between what i have and those next steps? maybe, probably. but maybe not. they would be very expensive and not compatible with my retirement lifestyle. would they be worth worrying about? unlikely. but vinyl development is probably not done. nor do i want it to be.
i moved from the Saskia to the Esoteric T1 so i could have three arms and it could be my last tt. i do view it as my end game. also love the CS Port too for it's own sake.
until i processed (cleaned and curated) my acquired 3000 pressing classical collection last summer i did feel i wanted to acquire more great sounding classical pressings. but now that itch has been fully scratched and i'm not looking for more pressings. i am more than fulfilled. so i feel i'm also at my vinyl media destination.
my urge to think about better vinyl gear can never be quieted. i'm hard wired that way. so i still dream sometimes, but then lay down till that feeling passes. or listen to my lovely vinyl. or go out and sit in my motorhome.
I am glad to read it Mike. You have scratched more itches than most of us have. There is always the "what if?". Enjoy the peace of knowing you have explored much and can now relax, listen, and enjoy what you have collected.
Reactions: Mike Lavigne
I should point out something you are not taking into account.
1) Guitar amps are not built to be hifi. There is often intention to build the amp to make distortion rather than to avoid it.
2) When any tube is driven, for example a power tube, the input capacitance increases with the drive. If the driver circuit isn't adequate to the task you will see crossover distortion in a push pull design. That is a design criteria; IOW a design flaw if the amp is meant to be hifi.
The video does not use much in the way of examples; your remonstration thus based on a logical fallacy.
We went round and round on this very topic on this thread yet you persist. I put you on ignore for this sort of thing; since there are two problems, the first famously outlined by an American author named Samuel Clemens. The second problem is when you are presented with technical information, you simply ignore it. I am hoping this is not done out of malice but the alternative, by Hanlon's Razor, isn't great either. You can chose ignorance or you can chose to learn. Its up to you.
Read this article. It disagrees with you about feedback improving zero crossing distortion. It also demonstrates why it is a bigger problem at low levels.
"The only point is to demonstrate that negative feedback can Never eliminate crossover distortion, because if both driver/ output devices are turned off, the circuit has no (useful) gain."
"Most audio power amplifiers suffer from a defect known as "crossover distortion". This distortion is particularly troublesome at low output levels. At low power levels, the crossover distortion can rise to a high percentage of the output level and become the dominant source of distortion."
"Crossover distortion is particularly insidious in that it is not usually harmonic. The timing of the 0-current crossover events is a function of all of the frequencies being reproduced by the amplifier. This interaction causes intermodulation distortion (IMD) which is much more audible than harmonic distortion (THD). The distortion tones produced by IMD do not occur where our ears expect to hear distortion. IMD can cause two musical instruments to interact in a way that produces distortion tones that are never naturally produced by either instrument. For this reason, IMD sounds unnatural and unmusical to our ears."
"Crossover distortion can create fast transients that are too short to be corrected by a feedback network. The feedback network can actually extend the period of time over which the error occurs. Most class-AB amplifiers will show crossover distortion artifacts that have been stretched in time by ringing in the feedback network."
So, I don't agree with your assessment that crossover distortion is like other distortions that can be dealt with using negative feedback and it is independent of level, so it impacts low level signals predominantly.
This what I am talking about. Notice the top trace is the sine wave output and the bottom trace is the residual with the waveform notched out. You didn't do this, nor can you with an analog scope!
It's inherent in how transistors are non-linear in turn on and shutoff. Here are many examples of even so-called Class AB that have zero-crossing distortion. If you don't put enough bias then it is guaranteed to be there.
The Class AB mode for this amp has zero crossing distortion and the Class A mode does not.
Again, AB has zero crossing distortion and Class A doesn't.
As you can see, many modern amps suffer this problem even ones called Class AB. Probably only the Naim would claim to be Class B.
The amps that are Class AB and showing zero crossing distortion are ones where the bias has been set too low and they are not completely eliminating the zero crossing distortion as the transistors are now in a quite non-linear region of their transfer function. You can call this poor design if you want but it shows clearly what happens when the bias is set too low...exactly what you get in Class B. However, it is likely there is always residual crossover distortion unless you bias at full Class A.
Doug Self lists the 8 types of distortion mechanisms when he is discussing his "blameless amplifier"
TABLE 1.
SOURCE ORDER SLOPE ORIGIN
1 Input stage (balanced) 3rd-order 18dB/oct Inherent
Input stage (unbalanced) 2nd-order 12dB/oct Inherent
2 Voltage Amplifier Stage 2nd-order 6dB/oct Inherent
3a Output stage LSN (4 Ohm) 3rd-order 6dB/oct Inherent
3b Output stage crossover Complex 6dB/oct Inherent
3c Output stage switchoff Complex Variable Inherent
4 Non-linear VAS loading Complex Flat Inherent
5 Decouple return in ground Even Flat Topological
6 Rail induction Even 6dB/oct Topological
7 Wrong feedback point Even Flat Topological
8 Capacitor non-linearity Odd 12dB/oct Inherent
The distortions we have been discussing are distortions 3a, 3b and 3c, which he lists as "inherent", meaning they are fundamental to transistor function.
He then states: "In a field like Audio where consensus of any sort is rare, it is widely acknowledged that crossover distortion is the worst problem afflicting Class-B power amplifiers. The pernicious nature of crossover distortion is that it occurs over a small part of the transfer characteristic, and so generates high-order harmonics. Worse still, this range is around the zero-crossing, so it is present at all levels, the THD percentage potentially increasing as output level falls, threatening very poor linearity at low powers."
Furthermore: "To further get the measure of the problem, Fig 23 shows how HF distortion is greatly reduced by increasing the load resistance, providing further confirmation that almost all the 8 Ohm distortion originates as crossover in the output stage."
So, a typical loudspeaker load makes the situation worse and particularly at high frequencies. The lower the impedance, the worse it gets for a Class B amp.
Finally: "This leaves Distortion 3, in its three components, as the only distortion that is in any sense unavoidable, as Class-B stages free from crossover artifacts are so far beyond us."
THat sums it up. He found a way to mostly eliminate all the distortions on his list EXCEPT distortion 3, which are inherent traits of transistors when running Class B.
Doug Self, himself, has declared that avoiding zero crossing distortion in Class B transistor amps is IMPOSSIBLE with current semiconductor technology.
Reactions: Amir and Holmz
I like the idea of avoiding crossover distortion in push-pull amplifiers.
Cross-over question:
My Clarisys passive crossover for the midrange/tweeter ribbon is 6dB slope at 500Hz. The crossover is positioned after the amplifier and before the speakers. Obviously it is a speaker level device.
What are the pros and cons of placing the same crossover in front of the amplifier at line-level (and then connecting the output of the amplifier directly to the midrange/tweeter driver)?
I like the idea of avoiding crossing distortion in push-pull amplifiers.
The idea may be less than the reality.
Pros: is that there is no (or less) voltage to supply as the octaves go lower… however I am not sure what that means for a transformer. That would be a Ralph Q-n-A thing, or a few others.
Cons: None I can think of, as there is no added cost for more stuff.
One could actually have that installed in the pre-amp, and that is how Vandersteen does their 6dB octave HPF.
Those cost a bit more that a capacitor and solder, but you get something that is engineered and does exactly that.
And it’s designed for 1st order, which I suspect could explain your allure with the Clarisys.
Thank you!
Crossover distortion in push/pull amplifiers is avoided by running the amp in Class A. See the Plinius examples above. In Class AB they have crossover distortion and in Class A it is absent.
I like the idea of avoiding crossing distortion in push-pull amplifiers. (...)
Then we should have our speakers impedance measured and plotted, including phase. Crossover distortion is also due to load.
BTW, the standard term is crossover distortion. Why renaming it in WBF? Or are you addressing a new mysterious musical distortion? ;)
Reactions: Johan K
My mistake, if it is never called crossing distortion.
Corrected in post 7,731.
Reactions: Johan K
Its not hard! I know of no tube pushpull tube amp with this problem unless it has a design bug. Its more something that can happen in a solid state amp if its biased so low its actually operating class C; IOW one output device turning off, then there's a slight gap before the other turns on.
IOW this sort of thing is a made up story; my surmise is its spread by people selling SETs. As I said before, its simply not a thing.
Now that isn't to say there might be something annoying about some pushpull tube amps compared to SETs. That can be caused by a number of factors, one of which has been known for over 60 years, which is that if the input circuit of the amp is single-ended and the output is pushpull, you can get more 5th harmonic, which just isn't all that musical. But that can be avoided in a pushpull design. The other problem, also avoidable, is improper application of feedback, typically applied the cathode of the input tube. That practice, which is still around due to tradition and nothing else, has also been known for the last 60 years to cause the feedback to make distortion of its own, making the amp less musical. This is because the cathode of any tube is not linear so the feedback signal gets distorted, which, if you want feedback to work, really shouldn't happen!
Crossover after the amp:
Pro:
the crossover is tailored to the speaker in many cases, often to deal with driver peculiarities. If the crossover isn't tailored in such a fashion the benefit is less.
Con:
1) In particular if you are running an SET, placing the crossover after the amp causes the bass energy made by the amp to be dissipated as a small amount of heat. Not the best use of amplifier power! Getting the bass out helps any amplifier, but SETs as I've mentioned before, are particularly susceptible to distortion if low frequencies are present.
2) Its harder on the power tube(s) since the output transformer in most SETs lacks the inductance to play bass properly, so even though you're not hearing it, at lower frequencies the load impedance on the tube is much lower than its designed for so the tube heats up, since more of the power its making is dissipated in the tube rather than the load. This can happen with PP amps too but its far less problematic.
Crossover before the amp:
Pro:
1) the amp is not receiving bass energy, so considerably more power is available at lower distortion to do its job with the mids and highs. This often means smoother with more detail.
2) Many people comment about the 'more immediate sound' when the amp is directly driving the speaker. No worries insofar as the output transformer is concerned.
3) The amp will run cooler even it its class A and the tubes will last longer. This is because the load line of the tubes will be more like the straight line its supposed to be.
Con:
1)the crossover might not be tailored for driver peculiarities. This may or may not be a real issue depending on the speaker.
2) an electronic crossover is an additional block in the amplification chain so noise and added distortion on its account may be audible. However some of the modern digital systems are quite good and allow you to tailor the response exactly to the driver.
Thank you, Holmz and Ralph.
Reactions: Holmz
(...) What are the pros and cons of placing the same crossover in front of the amplifier at line-level (and then connecting the output of the amplifier directly to the midrange/tweeter driver)?
Thank you, but I am using only passive filters.
Sorry, may be I am missing something on your post - are you really asking about using the same exact speaker crossover before the amplifier? This approach can't be used, the impedance and absence of load on the crossover forbid it.
