You still have not answered my question as to what characteristics your window is transparent. What do you hear from that transparent system?
I think your notion of characteristics through the window is the problem.
See if this analogy helps. I'm imagining a tank of water. In the tank is Stevie Nicks, breathing perfectly normally and happy.
Excellent transparency would mean there is no color or dye in the water; no dissolved solids in the water to obscure Stevie when you look through the tank; no waves; no sand in the water; no blurring vibration -- just clear, crystalline, see-through water, nothing adulterating in anyway your ability to see Stevie.
Transparency is a singular characteristic. It is a spectrum with total blockage and opaqueness on one end and perfectly clear, see-through, crystalline clarity on the other end.
Reactions: Johan K
What bikini is she wearing … or is that transparent too :D ?
Reactions: Johan K
Reactions: Johan K
No, the problem is the idea of using visual concepts to describe music. Your analogy fails because we don’t hear her singing in that tank of water. You’re stuck on pixel count.
In audio matters, we are talking about capturing information at one place, retrieving it, and then presenting it to the listener in his room. Consider a girl with guitar recording. You hear the notes and you hear the voice, but it sounds flat and lacks energy. The image is a bit too big and the guitar is not close enough to her voice. From what you have written, you would describe this presentation through a system as transparent, and I would not not.
Reactions: tima and Al M.
so then what separates transparency from naturalness? if you attach all these attributes to transparency it's just harder to use it to relate the idea of information. and i agree with the idea that the recording is a holistic thing; however sometimes something is very revealing, but not as involving.
visually we think of clear glass as transparent but it can be just patterns and colors and not seem to be alive and have energy. this is more my viewpoint. transparency is part of the picture and the more transparency mostly the better, but it's only one part.
One can have transparency and still have distortion.
As they say a picture is worth a thousand words… I just leave this here…
You still refuse to actually answer the question, Ron.
I hope you haven't been infected by Peter's confusion.:p
No, it seems that you are the one who is confused. We just apply logical thinking to the concept of transparency.
I think Ron is referring to the see through transparency of say electrostatics, where the presentation seems as if speakers have disappeared. This is different to the concept of transparency to recordings or ability to hear changes of recordings of upstream gear, which is not important to him and he might not have experienced to relate to the topic.
Reactions: Johan K
Reactions: Johan K
Why do you apply it only to the concept of transparency?
Reactions: Al M.
I see. I had thought the discussion was much more general in nature referring to overall system transparency. Ron did not specify it when Al posted his definition.
So, you CAN detect that the water isn't fully transparent. You don't see Stevie clearly, and you want to figure out how to improve that wholistic impression. It might be helpful to analyze what are the obscuring elements within the water that is fuzzing things up a bit (pigment, sediment, solvation creating a different refractive index, etc.). If you can identify these elements, then you have a chance to address them and improve you vision of Stevie. That's where thinking about the elements of sonic reproduction are helpful in trying to improve the wholistic impression of the music (dynamics, frequency response variation, phase, etc.).
Reactions: PeterA
That's why I don't think splicing in dynamics gets us anywhere.
Splicing it in isn't a thing.
First before we go any further, if SETs are involved we cannot ignore the simple fact that the word 'dynamics' means distortion and nothing else.
So I advise to not use that word if you really mean dynamic contrast.
FWIW, if the amplifier is truly transparent, it will not be possible for it to not also convey dynamic contrast, because quite simply to be transparent it is being true to the signal, from which dynamic contrast arises. They cannot be two separate phenomena. SET owners frequently do separate them, but that is only because of the distortion SETs make.
I understand why SET owners like their amps; all I can say to that is if they get to hear a properly designed PP amp there isn't any going back.
Ron went beserk on me a few years ago for sharing this picture ! :eek: Let's see if time and the new shape of the world has mellowed him out !;)
Precisely my point, for amplifiers or any other component.
To your point of being true to the signal, again from Stereophile's glossary of terms (emphases added):
transparency, transparent 1) A quality of sound reproduction that gives the impression of listening through the system to the original sounds, rather than to a pair of loudspeakers. 2) Freedom from veiling, texturing, or any other quality which tends to obscure the signal. A quality of crystalline clarity.
I still do not understand why Ron stubbornly insists on separating dynamics from transparency, especially since he has failed to provide a compelling explanation for that separation.
Transparency is the absence of some adulteration or fuzziness or neutral density phenomenon.
I don't even understand what that means. "Neutral density phenomenon"?
More or less dynamics does not obscure or cloud the window.
How so? Adulteration can also take place on the level of dynamics.
I’ve p’rolly seen it before too.
That is the good thing about tequila - one either doesn’t remember, or they do not want to remember.
It pretty much visually sums up the idea of transparency and distortion, although the SETs might be more transparent than the ‘doorty glass’.
Reactions: Lagonda
I think i used the picture to make a point about the beauty and "transparency " of tubes ! ;)
Reactions: Johan K
