GREATIm thinking about may be rewiring them / change the X over to a Series
GREAT
You can use external X over boxes with speakon connectors for either parallel or series and compare easily...
With a good series X over the different drivers blend in and you get a more single driver experience (in a good way).But what about the vid s sound ,? ( i like the sound with parallel X over too )
GREAT
IMO, if you got the impression that a series is better with your lower price range speakers there is no reason to believe that your top speaker wouldn't benefit as well. Generally might be a series easier to implement in a 2-way than in a 3(+)-way speaker but if technically feasible I would try it.![]()
Did you post a vid with the other x-over, playing same track?Yes thats a possibilty .
Yes this oneDid you post a vid with the other x-over, playing same track?
The smaller speaker is better, it's more fleet of foot/engaging, could be the x-over, could be something else, worth a try.Yes this one
Which one is better ??
This one...Yes this one
I can honestly say, this was the best video I've seen in a long time.... The sheer talent this little 4 year old has is amazing. I can only imagine how she will develop and hone her skills over the years!
I would love to hear this too. I was at AXPONA last month and was able to spend some time listening to the AV Duo Mezzo's G3 (I believe I have the model correct) with the tweeter and mids powered by Phasemation 300B pse and I really enjoyed my experience!SBNX cant you post a piano vid played on your system .
Id like to hear the AV trios G3 Itron on piano ??
Sounds congested...do you think having the other speakers in the room could be affecting the ones playing? Can you pick a better piano recording...this piano sounds broken...which I think it was.Another piece from the keith Jarret Album / Tape
Now with a 2,5 db tuned down tw @ 10 khz to get the in room response tuned down ( new small speaker in black )
FYI this is what basically all large speaker manufacturers do to get a more pleasing sound
