I am with Ethan, there is a limit to what you can hear, as far as level, in db down, in music.
Tom,
Can you technically quantify this limit? Or is this just a feeling with an undefined level?
Don,
The Carver challenge is part of audio history, but technically it is a undocumented experience, where we must guess most of the facts, and naturally people feel free to interpret it and make their own conclusions. Mine is that Bob Carver is a genius of electronics, and managed to make the two amplifiers sound the same in the conditions the challenge was carried. Whether they sounded similar because of the -70db null effect or anything else that Bod did to the amplifier was never established.
Again IMHO the audio crowds need simple facts and strong evidences to feed their folklore - the Carver challenge seemed adequate for this purpose, specially since it had the benediction of the TAS authorities, no technical documentation, just vague statements, and most of it, an epic formulation.
So what are you saying here, Tom - that the 70dB null was not a guarantee of audible equivalence & tweaks had to be made to the amplifer using his ears. That certainly is the way it's described in the write-up & to me shows that the 70dB is not the full criteria for audible equivalence of two amplifiers. How do you read it?Tube transformers shift phase. Thats a fact. Not a question. 70db is a deep enough null per subjectivists, who claim thier ears are better than measurments.
Micro, you have got to be kidding! The Carver challenge was the ultimate, epic, experiment between objective and subjective. You are a subjective person mostly, and you hear differences between amplifiers and such, and so can I when they are there to be heard. The subjectivist camp said they can hear differences between any two amps, and Carver proved they can not. They admitted it. They are the Golden Ears.
There simply is a point, in this case using a null technique as the ONE measurment, that proved, that subjectivists can not hear the difference between any two amps because audio science is above reproach as it can be manipulated to overrule the ear. It was done. The case was and is proved and closed....what was actually proved is that we human beings have a limit to our hearing ability. I don't understand why that is so hard to grasp by some (I am not saying you) on this forum.
Of course, the Ethan esperiement
"My AES Audio Myths video references hi-res Wave files you can download containing artifacts at various levels below the music. That section starts at 32 minutes in. Please tell us at what level the added artifact noise is no longer audible to you."
is also the same thing in a way, there is a point where in music, you can no longer hear a disruptive signal, there is a limit to hearing. In Ethans test, the only difference is the level of the interferene signal, nothing to do with the entiere system, just the source. THe better your system and ears are, the lower down the signal can be before you can no longer hear it. But you will no longer hear it and so will all the rest of us.
And Ethans experiment is easier, because you can hear the interference signal loud to start with, then go down in level. A more difficult, but accurate test, is to bring the interference signal up from below audibility until you can hear it.
70db is defined, and maybe even less (ie 65 or whatever). Carver defined it in one system, a high end system, hand selected by TAS, as being the best system to reveal music. Maybe if there is a dog around it would be different for him but for the humans with golden ears, it is no more than 70db, and in Ethans test, the ability to identify "distortion" is even less in music.
A very interesting technical paper dealing with null testing of an amp design - http://www-f9.ijs.si/~margan/Articles/Class_B_Dist.pdf
In Ethans test, the only difference is the level of the interference signal, nothing to do with the entire system, just the source. The better your system and ears are, the lower down the signal can be before you can no longer hear it.
TAS, by pulling a fast one, using a tube amp, think about it, TAS also allowed Carver to prove that the licquid midrange of tubes was nothing special and could be duplicated as well with a solid state amp.
Anyway, while waiting for your responses to my questions, in that test, the issue was that they used a transformer output amp, and it sereiously messes up low frequencies, so, to compensate, he tweaked some stuff by ear in his amplifier. And all agreed it was inaudible after that or did not matter.
[/B]
I will accept the Carver challenge at face value, -70db NULL!
OK, Tom, if I confused the message in the article then I apologise but I read it differently - I read it that he had achieved 70dB null but still needed to tweak it to make it sound identical.
Yes, I've read the story of this 'Carver Challenge' and it does sound a bit weird. He apparently stuck lots of pots all over the amp (an RF/noise/stability nightmare?) and tweaked until he got the 70dB null.
