Acoustic Research AR-303a Speakers
I'd like to stress that even though these speakers are very "recording friendly"--as in, they sound wonderful on most any program material--they are also quite transparent to differences among recordings and to changes you make in your audio system. You hear the differences, all right, but usually the nastiness that other speakers evince just isn't there with these.
I just power cycled my Xfinity router since I thought the presentation was getting too laid back, smaller/less expansive than usual, and less dynamically unstrained than usual. The magic is back, fully revealed by the AR speakers.
I was asked if the AR-303 and AR-303a are really different speakers, or just alternate names for the same design. In short, they are in fact two separate designs with the AR-303 release preceding the AR-303a release by about a year.
I have searched in vain for online discussions of any possible performance differences between the AR-303 and AR-303a. As far as I knew, there are only physical differences relating to the binding posts and bi-amp/bi-wire capability.
All the AR-303 units I've seen pictures of have a single pair of red and black plastic enshrouded five-way posts.
All the AR-303a speakers I''ve owned (the two pairs I own now and the other pair I owned more than a decade ago) as well as all the other pairs I've seen pictures of online have two sets of five-way binding posts that are gold-plated with jumpers connecting the two sets of posts. With my prior pair I removed the jumpers and bi-amped them with four channels of an Arcam AVR600 AV receiver. With my current two pairs I keep the jumpers in place and single-amp/single-wire them with the Lyngdorf TDAI-3400.
The pictures of both models reveal the nomenclature written on the back under the binding post plates. Mine are clearly labeled AR-303a, while the single post versions are labeled AR-303.
I have seen online comments saying that the 303 rapidly transitioned to the 303a when they were introduced in 1995. Other than that comment, I had not seen any discussion of the model differences.
But then yesterday I discovered brochures for both models captured on The Classic Speaker Pages.
The AR-303a brochure refers to the prior 1994 AR-303 model. See this image from the AR-303a brochure on The Classic Speaker Pages. The ad copy in that image says the 303a "features a redesigned crossover network, heavy duty 14 AWG internal wiring and bi-wire/bi-amp capability with improved gold-plated 5-way binding posts." The crossover frequencies and slopes are listed as the same in both the 303a and 303 brochures.
The earlier 303 series brochure can be found here on The Classic Speaker Pages.
Note that I do not use and have never used "bass traps" composed of large piles of fiberglass or other material. This would be impractical in small rooms like mine since it takes up so much space, even if I weren't concerned about carcinogenic fibers in the air, which I am.
And, frankly, electronic EQ works just dandy in the lower frequencies for removing bass resonances you might hear at the listening position. You don't need stacks of absorbing material.
If you are concerned about hearing uneven bass elsewhere in the room, you might be a candidate for using dipole bass speakers. Even in the bass pig concrete bunker basement room I had in my prior home, when I used electronic EQ to remove the bass peaks audible at the listening position, with dipole bass speakers the bass was quite even sounding even in room corners and along the walls behind the speakers and behind the listener, the usual trouble spots.
While I don't quite agree with some that you can almost never have enough high frequency absorption in your listening room, most people will be surprised how much absorption it takes to reduce slap echo audible from the listening position to near inaudibility.
I've mentioned this clap track test before, but this CD is worth buying just for that one track. Listen to how it sounds over headphones--most any headphones will do. You will only hear a sharp transient that sounds like a handclap, but with absolutely no decay following the initial transient. Listen to it on repeat until you understand what I'm saying and recognize what it sounds like not to have any trailing echo.
Now try to place absorption in your room so that, when played at a healthy level, that track when played through your speakers and listened to from the listening position sounds as close as possible to the way it sounds through headphones in terms of only being an initial sharp transient with no trailing echo. As I said, you may be amazed at how much absorption is required to pass this test. And it doesn't take Golden Ears to hear the difference between the headphone sound and the speaker sound. It will be pretty obvious until you get enough absorption in the room.
Once you have enough absorption in your room to pass that clap track test, you can go further, and add yet more absorption. If you do, however, the room may begin to make conversation in the room sound what I feel is unnaturally and annoyingly dull and damped.
Some serious music listeners aparently don't mind this and, technically, it is correct that in a listening room you really shouldn't be hearing any reverb from your listening room at all. All the ambiance you hear from your listening position should be from the recordings and absorption added to your room will increase the audibility of that rather than decrease it. But many recordings don't have sufficient recorded original venue sound, so they may sound a bit or more dry. Since there are no recording standards, you have to decide what sounds best to you.
I tend to not add additional absorption after the reproduction passes the clap track test--when the speaker sound is very close to the headphone sound of the clap track. At that point, conversation in the room still does not sound like it has a blanket over it.
I should add that you should expect the subjective SPL at the listening position for any given setting of your volume control to decrease at least a bit if you add enough absorption to pass the clap track test. Especially in small rooms such as I use, much of the sound you hear is from sound reflecting off room surfaces and once you significantly reduce the mid- and high-frequency reflections, the SPL you hear at the listening position decreases, at least subjectively. This is especially true of wide dispersion speakers like the AR-303a. Without adding acoustic absorption to the room surfaces, much of the sound you hear from the listening position will first reflect off room surfaces. If you reduce that refection significantly, it makes sense that the sound you hear from the listening position will decrease somewhat in subjective SPL.
This change is only subjective, however. I did experiments
where I measured pink noise from the Stereophile Test CD2 using the Audio Tools analog SPL meter on my iPhone. I set the volume control at the same minus 30 dB level on the Lyngdorf TDAI-3400 in both rooms and got about the same measured level in each room with the iPhone held at ear level a few inches in front of my face, about 65 dB. I also tried the same thing with some random program on MPR playing renaissance music and got basically the same results.
When I turn up the volume another 10 dB to minus 20 dB, it still measures about the same SPL in both rooms but at that higher SPL the unpadded room definitely sounds louder. Perhaps my ears are just defending themselves more in the unpadded room and that is what I'm reacting to.
Alternatively, it has been suggested to me that I should I think of this subjective effect in terms of Matt Mayfield’s famous video about the Loudness War.
Increased reflections are analogous to the compression and turning the volume back up that Mayfield describes.
Decreased reflections are analogous to restored dynamic range. With absorptive room treatment I want to turn the volume up. The music is both louder and softer and simultaneously sounds so much better.
Playing louder in an acoustically treated room feels the same in terms of loudness/comfort level as playing the music at lower SPL in an untreated room.
Whether YOU need to increase the volume in an acoustically damped room and thus need significantly more amplifier power to do that will somewhat depend on your reaction to the ways the sound is "better" with the absorption if you don't change the volume. You may not feel then need or even desire to turn up the volume. But I WILL say that once you are not hearing a lot of obnoxious early-arriving slap echo, turning up the volume control can be even more rewarding than before because you aren't simultaneously turning up the "room roar" from reflections.
In post #6 above I seemed pretty certain that the AR-303a speakers sound best with the grills on. I still use them that way in my AV system in my Blue Room.
However, now that I'm using the Network Acoustics Tempus ethernet switch and Muon Pro ethernet filter in my Audio Room, in that room I've found that the speakers sound considerably more open and three dimensional with the grills off. Yes, the tonal balance is also just a bit brighter with the grills off, so perhaps this is also part of what I'm hearing. But the added three dimensionality and envelopment resulting from the Network Acoustics equipment comes through much more clearly without the grills on. Without the grills, the system is now more than occasionally shocking in the degree of spatial detail and envelopment it portrays.
Recent thoughts:
I'm really not sure what is going on with the AR-303a speakers. The tonal balance almost always seems acceptably natural, at least after Room Perfect is applied, with no further EQ. And, compared with the Watkins Generation Four speakers I previously used, Room Perfect makes only minor improvements in either my audio room (where lot of absorption is used) or my A-V room which does not use a lot of absorption. Primarily, Room Perfect removes the slight midbass excess, the low bass is further strengthened, and the midrange is further smoothed, but these are all minor corrections which I have to concentrate to hear even on A/B comparison with Room Perfect bypass. With the Watkins, Room Perfect makes comparatively major improvements.
I would characterize the AR speakers' frequency response as "forgiving" in the best possible way: lots of energy from 20 Hz on up smoothly through the lower midrange, no excess above that, with a gradual sloping off of response above 4 kHz.
Yes, there could be more "air" in the top two octaves, but there is enough and it sounds clean enough, with good cymbal sound, if not quite enough stick strike on cymbals, but better than most in this respect. And, yes, the moment-to-moment dynamic changes could seem more dramatic, as they are with both the Graham LS8/1 and Watkins Generation Four, but, again, they are quite good enough on their own in this respect. And neither the Watkins nor the Graham can approach the very clean low and midbass power the ARs provide so easily.
One has to listen just about even with the height of the tweeter to hear them at their best in the mids and highs, but this is easy for me to arrange in both my audio room and blue room systems. The drivers also integrate just fine at only 50 inches away from them as I use them in both rooms, which is unexpected in such a design. They honestly sound as fine as Harbeths in this respect.
REG's response graph of his AR-303 speakers, together with his comments about the response, is at this link. My own measurements of my AR-303a's taken with the Audio Tools app of my iPhone from my listening seat in the audio room looks even more bass extended and smooth up through 4 kHz and about the same in terms of high frequency roll off above that. But keep in mind that my Audio Tools app uses 1/3-octave smoothing and REG was apparently using 1/6-octave resolution, so that would explain why my measurements seem a bit smoother in response.
Part of my personal reaction to the sound of these speakers undoubtedly is also nostalgic. I grew up with the classic AR speakers and these are a shameless Ken Kantor 1995 remake to sound more or less like the old AR-3a whose sound I adored back then, only with a bit more treble, better imaging/staging, and the ability to play considerably louder without driver burn out due to the use of modern ferro-fluid mid and high frequency dome drivers.
I'm sure that, as usual, I will eventually move on from the ARs in my audio room system. But, for now, I can't recall having speakers sound so pleasing to me on such a wide range of material with so little EQ and set-up effort. The balances among different recordings are easily distinguishable, just as easily as with any other speakers I've owned, but only rarely do individual recordings sound "off" enough to prompt me to apply a Lyngdorf Voicing to correct the sound a bit even though such Voicings require only a couple of clicks on my remote to select and apply. And, spatially, the speakers match the best I've ever achieved in my audio room with any speakers, again very surprising.
