Stirling uses digital to setup speakers and then uses records to setup the TT.do you know whether he exclusively used analog, or also used CD/digital references? did he bring his own vinyl pressings?
This part is for Ked.
Obviously, back in the day, before digital the two were combined and could not be separated. Today, we can separate the two. One has to listen to the TT through the speakers. combining the two is frought with error. Let me illustrate. We all know that the speakers should be setup to provide a solid central image on recordings such as vocals. This can be easily modulated by speaker position. The analog guys also know that the cartridge setup can alter the central image as well as it is reading the left and right channel out of the same groove. If one has a TT and uses that to setup speakers and they have the image pulled left then how do they know whether the speakers or the cartrige needs to be adjusted. These would be two very different things.
